Posts: 13 |
I am going to buy an SVT with a blown motor. if I buy a 3.0L motor, can I use the parts from the SVT on the 3.0L even though the 2.5 is not running. I am looking to do this and not spend lots of money on the car( under 5,000.00 total) I know there is lots of talk on here about the 3.0L and I want to do it. Any help would be great!!
2003 Dodge Ram 2500 Cummins stock
Posts: 3,570 |
In b4 teh search nazi's!
Anyway, depends on the condition of the blown engine. You can probably use the timing parts and just about anything else that isnt' already damaged.
Read up on the FAQ's.
Posts: 13 |
Hey dud, your car looks good. I want to go about the same way you did, hybrid type of swap. Im just don't have the knowledge of motors and stuff like that. I plan on having someone who knows contours help me but we'll see. Your car looks great though!!!!
Posts: 7,025 |
spend the $100 and buy a service manual. It will help you a lot.
Jim Hahn
364 whp, 410 wtq @ 4,700 rpm
Posts: 1,746 |
Read the FAQs in the 3L forum at NECO(fastcougar.com).
Posts: 611 |
The heads on the SVT I picked up a while ago were junk. When the engines go they spin a bearing and the piston hits the head. So a hybrid might be out of the question unless your lucky.
1999 3.0L Cougar: 220fwhp and 200tq
2003 VW Passat W8 with 4 Motion AWD
http://www.cardomain.com/ride/300644
PM for intrest in 3L SVT Contours, 3L swaps into your current car, Prepped 3L engines, or anything 3L related.
Posts: 3,570 |
Originally posted by contour21: Hey dud, your car looks good. I want to go about the same way you did, hybrid type of swap. Im just don't have the knowledge of motors and stuff like that.
Thanks man for the compliments.
A lot of guys are prefering to go with more of a full 3L route instead of the hybrid setup these days because the 3L heads have extra oil drainage holes which is beleived to be a great improvement. However a hybrid will probably require the least amount of modifications depending on your setup. I recommend you read the FAQ on the NECO boards and do a lot of research on the differences.
And as mentioned before, I definately recommend you invest in a service manual for the swap. It contains all specs and information you'll need.
Posts: 21,197 |
Or 3. I've used info off the service CD, Haynes, & Ford paper manual. We had them all open for Ryan's swap.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 13 |
Thanks everyone. I will do some more research on this swap. I may just end up not doing a hybrid, but I liked the idea of it because the motor would look about the same and maybe cost less. I read the Cougar pages but my computer did not load the pictures on the detailed "how to." I can get a blown SVT for about $500, so I will have to think about what to exactly do. What would you guys do???
Captain Impound Boy
Captain Impound Boy
Posts: 8,281 |
i would tell the guy with the SVT to return my emails! I have sent him 4 emails no reply!
I can't tell you what i would do becuase you would steal my idea.
