Posts: 24 |
Are the springs on SVT's lower than normal contours?
TCCA member in disguise
-99 Sable Wagon (ya thats right)
0-60mph in 10secs....:( dam vulcan
....wish i had a duratec
-Hopefully future contour owner
Posts: 9,602 |
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 392 |
DemonSVT: NO.
Are you sure, because i'm pretty sure that SVT are lower than normal tour. I own an SE and saw a lot of SVT where i work and they are lower. And it's the springs that gives the height.
Nic.
Contour 99 MTX V6 fully loaded, stock with 110000km. Illuminated sunroof switch. About to do the mystique rear dome light conversion with eyeball dome light.
Posts: 21,653 |
Not lower, they r a little heavier possibly lowering them a tad, and they have ground effects that make them look lower.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 4,639 |
i believe the consensus is they are same height, different spring rates
Hugo AIM:omegazodiac
Posts: 9,602 |
Originally posted by hmouta: i believe the consensus is they are same height, different spring rates
Exactly.
Zetec ATX
Zetec MTX
Duratec ATX
Duratec MTX
98 SVT
98.5+ SVT
95-97 SE
Those are the spring rates from lowest to highest.
2000 SVT #674
Posts: 21,653 |
They seriously have different spring rates for different trannys?
98.5 SVT
Posts: 534 |
it's all about matching the springs to the car. auto cars are generally a little heavier therefore requiring slightly beefier springs to compensate
2000 csvt #1553
Black/Tan
Posts: 768 |
and if you pay attention, you'll notice that they are listed the other way around
Posts: 3,867 |
I didn't think the spring rates changed between the E0 and E1. I know they reworked the struts, but...
Function before fashion.
'96 Contour SE
