#84718 01/09/02 07:49 AM
H
Head Offline OP
H
a friend gave me his kenwood powered sub and was not sure it worked since his head unit is broken.
well i tried to install it on my kenwood x815 and it does not work
i have never installed one and have no instructions was wondering if i did it right
i just hooked up rca cables and connected the blue\white wire to the power control wire on the HU, is this right
#84719 01/09/02 12:48 PM
APT Offline
So, you've got RCA cables connected to the head unit for the signal, good. The blue/white wire I assume is the HU power line, good. Now what you are missing is the power for the amp itself. You need a (probably 8GA) wire from the battery directly to the amp which is where the amp draws the current to drive the speaker.
#84720 01/09/02 08:14 PM
H
Head Offline OP
H
yeah i saw the battery wire on the sub thought it was for more power if you had a weaker car.
is there a premaid wire kit i could buy to run from the batt or do i have to fabricate somthing
thanks
#84721 01/09/02 09:12 PM
You just need something like this:
[url=Amp Power Kit]http://www.partsexpress.com/pe/showdetl...._ID=14974&DID=7[/url]
1999 SVT #900/2760
Born on 1-20-99
Silver Frost/Midnight Blue
A few aesthetic and audio mods
#84722 01/09/02 09:13 PM
Let's try this again.
Amp Power Kit
1999 SVT #900/2760
Born on 1-20-99
#84723 01/09/02 09:14 PM
BTW, don't forget the ground wire. The kit includes one.
Or, just go to Ratshack and buy some wire and connectors.
1999 SVT #900/2760
Born on 1-20-99
#84724 01/09/02 09:30 PM
H
Head Offline OP
H
i have the kit and my boy is coming over with the instructions and the battery wire he left in his truck
Moderated by  dnewma04_dup1
