#1073901 10/09/04 08:38 PM
BenS Offline OP
I tried calling my local "Murray's" and they said they didn't have anything on record for the light bulb in the clock illumination.
Anyone know where I can find one of these in S.E. Michigan?
thanks
-Black '96 GL 160k -Car #30953
#1073902 10/09/04 11:00 PM
for a direct replacement your Ford dealer
it is a bulb and socket all together but you don't get the green cover for the bulb
its around $3
#1073903 10/09/04 11:28 PM
Or do what I did and go to a junkyard and get one for a buck.
Champagne 1995 Ford Contour LX R.I.P. - 7/11/06 V6 2.5L 24v DOHC Oversized System
#1073904 10/09/04 11:53 PM
yeah, but the clock I got had a burned out bulb so that isn't always lucky
#1073905 10/10/04 01:49 AM
I just put in an LED and resistor when mine died. There is a post about this someplace in the forum. If you do this mod a good tip here is to point the led down to avoid the color spots on the back of the LCD. I've got a blue one in mine right now, but to be honest, I'm sick of blue LED's at this point.
#1073906 10/10/04 05:51 AM
I took a light bulb from my High mount brake light, and inserted it in, then went to junkyard and pulled all the light bulbs from the high mount brake light and replaced it.
All the bulbs for clock from junkyard = dead
Former owner of a 1995 Ford Contour GL w/ 2.0L ATX Proud owner of a 2005 Ford Taurus SE 3.0L V6 Vulcan --Looking for Commodore stuff (Drives, Units, Amiga, games, etc)If anyone has any of this laying around and wants it gone, lemme know --
#1073907 10/10/04 01:57 PM
I bought the correct bulb from Autoone, but it didn't have Ford's proprietary base. I just pulled the base out and soldered the bulb to the contacts on the clock board. It took all of two minutes to get it done.
-Keith '97 Contour GL Zetec 5spd '96 Mustang GT 5spd with an '02 engine
#1073908 10/11/04 05:03 AM
TGO Offline
you don't even have to solder it. just take the bulb and bring it to a local parts store, they'll find it. I got like 3 for a dollar locally.
1999 Silver Frost SVT #609 of 2760 Quaife, lightened SVT Flywheel, SPEC stage II clutch, removed resonator, k&n drop in - various other goodies too.
