#84583 01/05/02 03:40 AM
Philip Offline OP
how do you ground an amp without running a wire to the engine block, or negative battery terminal. Is the trunk grounded? Can i just bolt it to an unpainted metal spot in the trunk
Silver 1998 Mystique LS (v6)...ATX frown
Removed Emblems, limo tint, painted calipers.
Premier P630 HU with 4 Pioneer TS-A6895 Speakers with 10' Sony sub (yeah i know, i'm cheap)
Commando 501-S Alarm
#84584 01/05/02 03:54 AM
yep
#84585 01/05/02 03:56 AM
a great grounding spot is the bolt that hold the seat belt . I have been using that spot for a ground for many years I currently have a concept 2400d amp grounded on my rear seatbelt bolt for about a year and it works great smile
95 contour gl
2.5 v6
p.o.s. car (LOL)
#84586 01/05/02 07:44 AM
I used a screw behind the plastic cover in the trunk that way its close t my amp so get less distortion th little plastic screws that hold on the plastic cover are easy to get out too
Infinity 6 1/2 in. speakers in all doors
2 10in. Kenwood Tornado Subs
Logic Soundlabs 840 watt amp
my car would be sweet if the cops didnt take all my money
#84587 01/05/02 02:33 PM
When you do the amp wiring, Make a new ground for the battery too. It helps alot and since you are already running wire...
Moderated by  dnewma04_dup1
