#1070766 10/06/04 04:33 PM
I have a small oil leak on the front left of the engine around the oil filter and ac compressor. Anyone have any ideas about what might be leaking from there? It leaks onto the ac and then onto the exhaust.
Thanks.
The right thing to do. VOTE BUSH!!!!
#1070767 10/07/04 12:40 AM
I have the exact same problem. Can't seem top pinpoint it.
www.ChicagoCEG.com 2006 White Grand Prix
#1070768 10/07/04 12:44 AM
get the motor steemed cleaned for 45.00$ and then start the car and visulay inspect the area....sometimes what looks like its comming from one place is realy leaking form another.
Check your Oil filter, (clean it by hand, as good as you can)oil pan gasket and vlave cover gasket (yes valve cover).
Lupe
#1070769 10/07/04 12:50 AM
If you have a 2.5 L engine then it is probably the oil sensor. It is just above the a/c compressor. With the engien cool you can find the wire lead to it. I had the same problem. Bought a new sensor from ford. aftermarket did not have proper wire connector.
Bob
#1070770 10/07/04 01:45 AM
I will check the oil sensor tomorrow and let you know if that is it. Also I will check the gaskets.
