Posts: 1,231 |
107 thousand ks. new front wheel bearings plugs, wires and ignition coil (some nasty rot fried it all) Everything else is just previe maintenance
95 Merc Stique
Zetec 2.0 Auto
Posts: 8,301 |
I have 74K so far, and all I have had fail is a temp sensor, but after removing it and putting it back in, it still works fine. Other than fluid changes, filters, and a set of front brakes, the car is still all original.
Like someone else has already said, dont expect anything to fail, just keep regular maintainance on everything.
-Ken V.
psycho_bass@hotmail.com
Posts: 5,143 |
About a month after I started to drive Conty, I had to have the Timing belt done (about 102K miles?) Then shortly after I needed spark plugs(went through 3 sets before I got the right ones) Wires (Soon to be replaced with for Racing wires... Thanks to R_G) Coil pack. Then shortly after that I needed to do my Right back brake, the Cylender was shot in it, so my uncle, dad and I replaced the whole thing. Took about 4 hours. Now, I believe there is nothing to important wrong, besides having to replace my PCV valve. I should be cool
98 Corolla LE 1.8L DOHC 1ZZFE
TEIN H.Tech Springs
Tokico HP series Struts
Short ram air intake
Tsudo Axel Back Exhaust
Posts: 66 |
Well, I've had the car for over a year now and bought it with 78,484 on the odo. Now it read approximately 83,500...and in those 5,000 miles I've had to replace nothing. Though I did have to replace all my spark plug wires which was not a fault the car had, but rather rats that crawled up into the engine bay on cold winter days and chewed right through them. Needless to say I was pissed handing over the money to fix that, but hey at least it wasn't the car failing.
Posts: 122 |
Originally posted by HITMANinMI: well I do this every 10k or so, I'm about to nail 70k. Last time I posted this it was when I hit 60k, now 60k -70k wasnt that bad to be honest, some stuff, wheel cylinders, power window switch, few other things. Anyways for those with miles on their car, unlike mine what can I expect to fail between 70k-80k? I know every car isnt the same, but just a general idea. Anwyays not this year but next year March or so I plan to replace the PCV valve/hose, few filters, intake manifold gasket, valve cover gasket ( leaks slighty as it is), replace IAC valve, clean EGR valve, flush coolant, clean A/C high pressure switch.
thanks
dude, where did you get your rims/wheels for your car? Look great
Posts: 2,725 |
Thanks, they come off some SVT Contours.
Posts: 5,143 |
yeah, I have the same ones on my car. They are the SVT E1 Cobra Style rims. You can get a set from another CEG'er for really cheap used.
TEIN H.Tech Springs
Posts: 36 |
75,000 with no major problems, except my cup holder self destructed.
Posts: 35 |
Bought mine at 130,000 1997 model Had to change wires Spark plugs Had the radatior flushed and fuel injecters serviced Installed K&N filter. Now it needs a tranny!
CEG road warrior
CEG road warrior
Posts: 17,248 |
So far:
4 sets of wires
5 sets of plugs
3 coils
3 thermostats
2 new timing belt tensioners
1 new ECU
3 timing belt changes
4 new serpentine belts
1 waterpump change
3 radiator replaced/3 flushes
3 trans flushes (one on the way)
replaced all the wheel bearings
replace drums/hardware/shoes then converted to rear disc
3 sets of rotors/pads
new VCT
new powersteering lines
3 new o2 sensors
3 valve cover gasket changes
numerous bulb replacements
over 120k on car= a lot of oil changes (do the math)
new SS braided brake lines.....old ones looked bad
4 fuel filter changes
new camshaft position sensor
I probably forgot some.....that doesn't even include all the mods.
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
