#1069704 10/05/04 04:23 PM
My 95 v-6 Auto just had a trans rebuild less than 1000 miles ago. Now after about 2 days of driving, CEL comes on and trans starts shifting HARD. It will actually chirp the tires when it hits 2nd. After i clear the codes from the computer its fine again for a few days. The only codes that come up are excessive torque conv. slippage, and excessive exaust back pressure. Any info on this? I find it hard to belive the new convertor is slipping.
I have a 5 speed doner car i was going to swap over, but would like to keep the auto if i can fix this problem.
CRASSELL 95 Contour V6 auto 96 Contour V6 5 spd 97 Contour 2.0 Auto
#1069705 10/05/04 05:17 PM
Chances are they did not actually repair and update the baypass and regulator vales and just cleaned the VB. The baypass valve wears out and sticks. It can�t be cleaned or even replaced, the bore has to be honed and a redesigned (Sonax) valve used.
Bring it back.
Also do a search on code 1744 and Torque converter slippage. ( I think the code for 95 is 640, or 634. but don�t quote me).
jeff
have you fixed your ford lately?
