Posts: 12 |
i thought i had my car all cleared up with the CEL problem. i took the 75mm mass air off, along with the chip,(stayed clear for over a month!!!) and last friday nite i got a check engine light????? i put it on the scanner from work, and it said P0420....... catalystic efficency something something......BANK ONE! what may this be refering to? as i cleared the code to see if i would get it again, and go figure it happened last nite which was a week later, and 230 miles after! the first time i had issues with my tour running poorly, (2000 SVT) it also happened on a friday nite! maybe ill just stop driving it on fridays!  give me a hand here! im putting her into storage at the end of october, so i would like to enjoy her while i still have this month left! thanks
Posts: 192 |
one word...search
i know i have put up at least 3 different posts about this
FOR SALE: 2002 Chevy Caviler, 34,000 miles, 6500. check out the classifieds
99 SE ATX
89xxx miles still running strong
Posts: 496 |
Posts: 12 |
thanks.........maybe next time you will realize you are searching on the forum section for quick easy answers or to HELP someone out, hoping you can one day get it in return! i dont really have much time having a 1, 4, and 6 year old to get to my computer and spend all the time in the world! i used to use a different user name, but over time i have forgotten the password....... but i always posted with rather helpful replies, not just a search! also, im rather discusted to know that there are people part of the COA, that are so rude. i have owned my 2000 SVT since new( meaning i am the original owner) and my warranty has just ended in july. all i was looking for was a link, or a quick hint! thanks for your help to those who have helped! for those who dont, maybe you should spend some more time on eBay! you would make a good DEADBEAT bidder!
Posts: 282 |
check this links out, they have alot of useful info on the 0420 code. 0420 code other link for 0420 code Cheers Suriel
Silver
'98 SVT
3356 of 6535
8/29/97
Posts: 39 |
code 420 refers to the O2 sensor, specifically the #1 bank above or before cats, this is the sensor right by the fire wall under the coil pack. their is a how to in the howto section, i hope this helps
98.5 Silver CSVT
93 Black TBird SC
Posts: 1,788 |
Originally posted by asystole: code 420 refers to the O2 sensor, specifically the #1 bank above or before cats, this is the sensor right by the fire wall under the coil pack. their is a how to in the howto section, i hope this helps
Uh, no!
Catalyst efficiency test, as already noted.
Steve
89 Taurus SHO - 246K miles
94 SHO ATX - 190K
Posts: 282 |
Originally posted by projectSHO89: Originally posted by asystole: code 420 refers to the O2 sensor, specifically the #1 bank above or before cats, this is the sensor right by the fire wall under the coil pack. their is a how to in the howto section, i hope this helps
Uh, no!
Steve
a how-to should be posted on this specific code and the possible ways to fix the code...this specific code has been beaten to death. i posted 2 links about this and have many more posts saved because i had to deal with it and i researched it in great depth...
ok done venting
Cheers Suriel
Silver
'98 SVT
3356 of 6535
8/29/97
Posts: 12 |
thanks for the help....... hopefully i can find some time to investigate the situation this week! ill keep you posted!
