Posts: 207 |
I couldn't really think of a better title..
Anyway, ever since I put on my 17's there has been a huge vibration feeling in my steering wheel when going over 60 MPH. Sometimes it does it when I'm going lower speeds, but not as bad. Basically, my steering wheel just vibrates like crazy. There's no vibration feeling in the car itself, just in the steering wheel. It's pretty annoying and not all that comfortable to ride with.
Anyone know what the problem is if there is any? Or is this something I'll have to live with because of the new rims/tires..?
Posts: 1,238 |
Alignment and/or wheel balancing. Damn Im good.  -tropictour
2000 Contour SVT
Tropic Green
SHO Shop CAI
Bassani
1999 Contour SE
BAT Kit
Posts: 1,055 |
Originally posted by tropictour: Alignment and/or wheel balancing. Damn Im good.  -tropictour
no and or, an alignment itself isnt going to cause a vibration... now tire wear due to an alignment could cause this.. Damn I'm good
Derek Johnson
88 TurboTBird 32psi, t3/t4 bb 50trim, megasquirt, 3 bar map, 50lb inj, roller cam w adj. gear, header, 3" downpipe and full exhaust, gutted intake manifolds, spec stg 3
95SE 3L gone
Posts: 21,653 |
Unbalanced wheels could though by itself. Also if your supposed to have hubcentric rings and don't, it could cause it.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 1,238 |
Originally posted by 2.3Turbochicken: Originally posted by tropictour: Alignment and/or wheel balancing. Damn Im good.  -tropictour
Well based on my experience I have had a vibration before an alignment.  -tropictour
2000 Contour SVT
Tropic Green
SHO Shop CAI
Bassani
1999 Contour SE
BAT Kit
Posts: 1,756 |
Are these wheels replacing the stock wheels? Did they remove the clip located on one stud per wheel? If not, that could cause vibration. It did for me.
CEG road warrior
CEG road warrior
Posts: 17,248 |
It is the balance.....
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 1,609 |
I have this same problem except i just had my wheels balanced and mine are 16's. Bill
1998.5 SVT contour #5979 3L
1995 Mercury Mystique 2.5L auto, all ghetto fo sho
Posts: 326 |
Like others have said, it could be balance.. Also could be tires that are out of round.. its possible... my 17's do the same since I got them balanced twice, and now that the tires are almost shot the vibration is worsening... i've actually had the car up in the air and idled the car in first gear... and noticed mine were out of round. in the spring I won't be buying cheap tires again(federal 595SS's)
i've returned to my 16's with just race tires on them, and they are smooth rolling. so i know its not car specific in my case.
99 Cougar V6 Tourmaline Green: MTX, KKM, Borla Dual...
Posts: 230 |
I had the exact same problem because my tires were worn unevenly. I got 4 brand new tires got them balanced and got the alignment. Problem fixed, no more vibrating steering wheel.
"Why do we drive on parkways and park on driveways?"
