Posts: 1,287 |
ive tried the sanding, polishing, waxing, and my headlights still dont clear up....i dont wanna buy new ones....so what can i do?
Posts: 2,203 |
You're positive you're using the right grits of sandpaper and the purposeful Clear Plastic polish/wax? Another quick, temporary fix is to spray some Wet Tire polish on the headlight, but it's definitely not permanent.
Posts: 1,287 |
ive got black magic tire wet....how long will it work for?
Posts: 301 |
When I originally sanded my headlights..I'll tell you the truth it didn't seem to work.
The results will happen all at once. I Wet sanded them using my electric sander w/ 1500 grit sandpaper. It took 30 minutes per headlight. You'll know that you need to keep going if when you dry it off it hazes up immediately. What you should do is either switch to a 2000 grit paper or continue to sand with the 1500. After a LONG LONG time, the results will show up. I didn't have wax and my dads experimenting with tire shine(meguiars) on the headlight produced a pretty much factory-new headlight. It lasted for about 1 month. By then though I already had my plastic wax so I was fine.
~darp~
The moral of the story is keep sanding.
Originally posted by PÃ?â?¢WDÃ?â?°Ã?®CÃ?Ë?Ã?Æ?TMÃ?â?¬N: I can do anything if i can find that powder .
Posts: 835 |
This is exactly what Im doing right now. Its funny to find a post about this. Its a little different from what everyone here is doing or did. Im sanding my headlights to remove all those tiny spider web cracks off my headlight. So far I have removed 90% of it. It looks so much better. I went though 4-5 different sandpaper grades to remove these tiny cracks. They were 150-400-600-800-1000/2000 sandpaper grades. Took me several hours to do this. I did use an electric sander, however, it leaves some nasty tiny circles behind. Its best to do it by hand. At the same time Im also painting them black inside. Ill post photos as soon as Im done if y'all like.
-dan
98 CSVT 484/6535,18" MI Rims,Nitto NEO GEN Tires,Pioneer DEH-P7300,Custom Cougar CIA,CF Hood,McCULLOCH HID 6K,Custom painted red calipers,Flowmaster 40s mufflers,Drilled Slot rotors,K&N 9" air filter,Brullen HiFlo Y Pipe & CAT,Magnaflow Res
Posts: 9,872 |
Posts: 69 |
I would just get new ones, im getting mine in 2 days it will definitly be worth it. sanding sucks.
(Mike M.)1998.5 CSVT black
17" enki cdr9's-(on pirellis)
b&m short shifter
custom grills
audi a6 sidemarkers
a-pillar pod w/3gauges
oil press/volts/air-fuel ratio
clear corners
15% tint
TRUE DUALS(sounds great)
mirko spliter
and more..
Posts: 2,975 |
Originally posted by MUCCSVT: I would just get new ones, im getting mine in 2 days it will definitly be worth it. sanding sucks.
Give tem over to me then. I need a passenger-side badly.
1992 Ford Escort LX-E
-Tracer LTS spoiler
-GT Grille
Posts: 9,872 |
hopefully they aren't cheapo depot
Posts: 1,287 |
Originally posted by PlatoSVT: You're positive you're using the right grits of sandpaper and the purposeful Clear Plastic polish/wax? Another quick, temporary fix is to spray some Wet Tire polish on the headlight, but it's definitely not permanent.
what steps should i take applying the tire wet
