OK....I did exhaustive research and followed the recomendations. It seemed like it would be quite simple. It wasn't. I first replaced the stock fog light bulbs with 885's and you all were right, a lot brighter. Now, as you all know, the stock lights are aimed rediculously low even when adjusted to the max. The fix as you all said was to remove the adjustment screws and snip the springs. Well, the adjustment screws refuses to be backed all the way out and seems to me that if I continue, I will most likely twist the suckers off. This is a small thing except that I am trying to keep from spending $200.00 plus for PIAA 510's. Which I will most likely do but down the road, I hope. So the question is, have any of you good folks ran into this problem with the adjusters?? As always...thanks for your input....Steve
