#1061349 09/25/04 05:14 AM
Ok, i know there is a list of "to do mods" already on here...but want to ask a question about some...first what is this "E-Ram" i here about....also...i've just been to the track tonight..and i've noticed that my car runs better like when i first get there after i've let it cool off...then it gets just a lil slower after it heats up..it stays about the M or A while sitting still...i was wondering if a thermostat would be the best solution to this...if not then what else...also thought about an oil cooler....any thoughts???
1998 Contour SE Zetec atx, intake, custom dual exhaust, ngk iridium plugs, 8mm wires, svt body kit, 17" motegi mr7's, b&g springs http://www.cardomain.com/memberpage/366279
#1061350 09/25/04 12:23 PM
hmm not too sure what your saying but an oil cooler wouldnt be a bad idea. Had the car long? if ya dont know whats been done to it id just go down the list and do it all just to be safe. I bought mine used and had no idea on servicing so i did that.
95 Merc Stique Zetec 2.0 Auto
#1061351 09/25/04 10:02 PM
Oil cooler is a great mod.
I have a B&M oil cooler installed.
Cut oil temps by about 15-20 degrees.
If you do get one, make sure you get a thermostst that doesn't let the oil start cooling until after its warm.
Most are standard at 180 degrees.
The ERam is an electric supercharger.
It DOES work.
It is the only electric supercharger proven to work.
Do a search through the forums and you'll find all the info you need.
They are spendy at $300, and their gains are only at WOT, but could be worth it.
Frank McCoy aka Mod-deth aka Mid Life Crisis aka SVT Doood aka mcgainer is a SCAM ARTIST Pre98 Zetec - Some Mods
Moderated by  Loco4G63
