here is a list:
1.Oil
2.oil filter
3.spark plugs (wires usually fine, but might want to just to get everything new)
4.trnsmission oil and filter (if automatic)
5.Transmission oil for Manual ( Redline MTL, ATF 3 if tranny is having problems)
6.fuel filter
7. air filter
8.UIM/LIM cleaning (in the FAQ on
www.contour.org main page)
9.throttle hang fix (same place as UIM/LIM cleaning)
10.clean throttle body/optimize (sam as above)
11.Optimize secondaries (same as above)
12.New PCV
13. coolant flush
14. P/S flush
15. Break flush
16. break inspection
17. suspension inspection ( no leaky axle boots, or clunking nosies, obad shocks)
19. check tires and inflation
20. new gaskets to replace any that are damaged or that you remove parts form.
21.might want to rechrge AC
22. while doing coolant flush might want to inspect water pump, they ahve a tendance to go bad if there the old black ones (i believe thats it) gray or white is ok...metal is better....and check T-stat.
DRINK A TALL GLASS OF BEER!
Lupe
