Posts: 862 |
I swapped from drum to disc tonight. COst $50 at the parts yard. The hardest part was carrying my tools and the both complete hubs with all hardware out of the yard. It took 3 hours to pull the donor parts, pull my drums and replace the disc in place. I had to get a female to female brake line adapter since my body hard lines were male and so were the donor caliper hoses. I know it is mostly for looks but it does seam to stop much better now.
ATX MTX swap, rear drum disc swap, drilled rotors, ported intake, optim throttle body, CAI, 7.5L MAF, adj. fuel regulator, longtube headers, underdrive pulley, no EGR, low inpedence bigger injectors, 2002 Focus Swap
Posts: 637 |
Cool. Sounds like you got a good deal on the parts, too. Where did you get the adapters?
I've been looking for used parts for a disc brake swap for several months now. The best price I've gotten so far is $150 for very high-mileage un-rebuilt parts at a junkyard in L.A. (fifty miles away from here).
Posts: 134 |
So it was worth it ! I've always like 4 wheel disk brakes mself . I've though about doing the 12 inch focus switch but i havent done it yet .
Posts: 862 |
The adapters were at autozone for $0.99 a piece brass connectors. Yeah I was happy with the price I paid.
Posts: 635 |
Does your Tour have ABS? Curious about that would work without ABS and those PCV valves on the rear drums? Paul
Paul
98 Mystique LS 2ea (07/97)(08/98)
Posts: 862 |
Yeah its got ABS. What pcv valves? I did notice that sum tours at the wrecking yard had valves of some sort between the brake line and the brake hose for the rear drums. But not all of the cars had this and mine didn't either.
CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by F111D F: Does your Tour have ABS? Curious about that would work without ABS and those PCV valves on the rear drums? Paul
Valves? I didn't have any on mine.....besides I changed the brake lines when I did the swap.
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 21,653 |
[quote=F111D Fthose PCV valves on the rear drums?
HAhha, what?
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
