#1057705 09/22/04 01:11 AM
Alex532 Offline OP
Okay, I searched forever on vacuum lines but found nothing on the detailed routing of them. I had all of my vacuum lines off of my engine while I was working on it and for some reason thought they did not need to be labeled before removing them.
So far I have have the green one back on the EGR valve, a black one running to the A/C system, the EGR vacuum regulator control hooked up, and the control solenoid vacuum line hooked up. So I have an extra red line up by the manifold that I have no home for. I also have two hoses coming off of the exhaust manifold EGR tube, one is connected to the EGR pressure sensor but I have no home for the other one. Can someone help?
#1057706 09/22/04 01:41 AM
Is this a v5 or 4 cylinder?
#1057707 09/22/04 03:45 AM
V5? Considering he posted this in Duratec maintenance I'll assume he has a Duratec......
See if these pictures help.
1996 2.5LT V6 Contour ATX My Tour+help/info pics E0 rims, Gutted Pre-Cats,CTA Custom Exhaust & Intake, Diablo Chip.
#1057708 09/22/04 05:02 PM
Alex532 Offline OP
It is a V6 2.5L.
Chongo, pictures always help, now I can explain better what I am looking for. The two lines shown in your pictures with the orange caps on them, those are the two that I can't figure out where they go. Also, from the picture, it isn't clear where the second rubber hose from the exhaust manifold goes, do you know? Thanks
#1057709 09/22/04 05:45 PM
okay here's more picks. Remember this is from my 96.
#1057710 09/22/04 09:37 PM
Alex532 Offline OP
That does help too, so now I know the red one goes to the evaporator/AC system. I still don't know where the black one goes though. Do you have any other pictures, maybe a picture of the EGR hoses coming off of the EGR tube?
Thanks
