#1055569 09/20/04 02:44 PM
GVSUSVT Offline OP
Alright, i've done some searching, and I belive that I have a bad IMRC, but would like some opinions.
Here's the deal. About 6 months ago, my car began to act like it was not getting enough fuel when at higher RPMS and below a 1/4 tank. This initially led me to belive the fuel pump. However the problem has now migrated to where if I have 1/2 (and sometimes 3/4) tank or less it's causing the same issue, feels like it's not getting enough gas over 4k RPM. It only does it when under load, ie. acceleration, not when I just rev the engine.
Occasionally I'll get a really high pitched whine (much like alternator noise, except it's comming from the engine). It's not the typical moosing noise, I've had that fixed.
The CEL came on a few weeks ago, so I need to get that checked, and it may tell me more. Would a fuel pump/IMRC throw the CEL?
What's your opinion, IMRC, Fuel Pump, Fuel Filter? Where should I start as to not cost an arm and a leg.
The car has about 90,000 miles on it, the engine was replaced about 30,000 miles ago with a complete tune up done at that time.
2000 Black SVT.. Good thing I'm single.. no way I could afford a g/f AND the repairs on this thing
#1055570 09/20/04 02:49 PM
The IMRC could very well be the cause. They run about $120 at the dealer. I was having the same problem. I actually just replaced my IMRC 2 days ago and I have noticed an astonishing improvement.
Good Luck
98 Contour SVT (soon to be reborn) 2000 GMC Envoy... Screw you guys, I like it. 89' Mustang 5.0 (Just bolt on's... for now)
#1055571 09/20/04 09:13 PM
I'd try to move the imrc cams with you finger to see if they are stuck. if they are, remove the upper intake manifold and clean the plates..
