Hello all. I have been through all the threads and can't find anything that quiet matches my issues.
I have a 95 2.0. My basic issue is that when you start the car and put it in drive or reverse or turn on the A/C (basically, anything that puts a load on it) it will lope, stutter and ussually stall unless I give it fuel.
Now, it drives down the road great and has pleanty of pick up. Sometimes when I start it it will sit and Idle fine unless I put it into gear or turn on the A/C.
I have checked the IAC and it seems to be working. It has new plugs and wires. Several of the sensors were replaced by my brother before I took over the car. I can't hear any obvious vac leaks using a hose to my ear. I have cleaned the MAF sensor and it does the same thing with the entire intake tube removed all the way to the throttle body.
Any ideas out there? I took it to ford and they said that I need to replace the harness before they will run codes. Everything else works great. The car has 190K on it and none of the recalls were done before I got it.
I could use the help ASAP. I am trying to get this thing on the road before my explorer goes into the shop.
Thanks a million,
Hallboy
