Posts: 167 |
I haven't seen anything like this...and I'm usually pretty anal about making sure both lights are lit (always look for both in the reflection of the car in front of me). So unless both burned out the same day and time, I don't think it's a bulb issue.
Needless, both fogs quit working, and to make it even better, the indicator light on the dash doesn't light up either.
I checked the fuse for the fogs under the hood...and even swapped it out. I also physically looked at the bulbs, and I cannot see any breaks in the filament.
I rewired the fogs back in 2000...so I'm hoping it has nothing to do with that. I soldered the connections...so they shouldn't be broke.
Anyone else ever run into this, and maybe have any possible suggestions for getting these to work? Maybe it is something with the switch?
Thanks
Joey
2006 MazdaSpeed 6 Black Cherry
2004 Jeep Renegade Black
2000 SVT Black
#1811 of 2150
Dad always thought laughter was the best medicine, which I guess is why several of us died of tuberculosis.
Posts: 2,319 |
Does the fog lamp relay click when you operate the fog lamp switch?
Posts: 167 |
Originally posted by horseydug: Does the fog lamp relay click when you operate the fog lamp switch?
Actually, that's one thing I forgot to mention...I don't hear it.
Joey
2000 SVT Black
#1811 of 2150
Posts: 494 |
I happen to have the complete wiring kit for foglights (minus the foglights)if you need it.
PM me if interested.
2000 WS6 Convertible A4 13.11 @ 107.5 with a lid, Ram Air and LTs
Gone:95 Mystique LS Young America edition V6, MTX 15.6 @ 91
Posts: 6,910 |
i beleive if the indicator doesn't turn on then the relay isn't working
- 95 Mystique LS - Zetec/5spd
Posts: 2,975 |
And to check for that, use another relay from the fuse box.
1992 Ford Escort LX-E
-Tracer LTS spoiler
-GT Grille
Posts: 167 |
Originally posted by Cris'pus: And to check for that, use another relay from the fuse box.
Fantastic idea...there are ones that are the same size I take it.
Joey
2000 SVT Black
#1811 of 2150
Posts: 509 |
This sounds similar to the problem I'm having.
My battery light is coming on sometimes as well and if I pull fuses 4 and 11 (i think that's is a 20 and a 3 amp) everything works again?
don't drink and drive.
Posts: 509 |
I'm gonna go check this out, where's the relay located?
Posts: 2,975 |
Originally posted by rollingstash: I'm gonna go check this out, where's the relay located?
Open your engine fusebox, then open your car insturction manual and find the fuse explanations. I think it's page 112. Presto.
-Tracer LTS spoiler
-GT Grille
