Posts: 869 |
Ok, my thoughts have been spread out over several different posts, and this is what It's come down to: posted November 26, 2001 07:20 PM -------------------------------------------------------------------------------- For drop-in simplicity, I'd go with these Audiobahn plate components for $100. Very efficient with external, switchable crossovers. Audiobahn 6x8 Plate Components [img] http://store6.yimg.com/I/competitiondirect_1657_57261245[/img] The Crystal 5x7s from http://www.carmedia1.com/crys.htm for $69 (1 pairs) Crystal 5x7s with external crossovers or last but not least a pair of cerwin vegas, dropped in price on crutchfield to $80: I apologize in advance for everyone who has listened to my questions about speakers for the last week, I just like to know exactly what I want before I buy it. My HU has EQ settings to focus on front passengers, I assume it cranks front speakers. If I go crystal I could stretch out 2 pairs, while everyone talks about front sound stage, my system with only HU and speakers would crank louder with 4 real speakers than 2 real and 2 ford, correct? I think this post is going to help out a lot of people cause despite using the search function till I wanna puke I am still left with ?'s which I see reoccuring in other posts... 1.) Audiobahn - $100 2.) Crystal - $69 (could stretch 2 pairs) 3.) Cerwin Vega - $80 Many of you that are actually knowledgable in car stereo and am probably sick of me asking just reply with 1,2, or 3. This vote will help me a lot. Thanx!
2000 CSVT #1172 of 2150 Toreador Red...Birthday -> 1/4/2000 *Indiglo Gauges *Drop in K&N *Sylvania SilverStar Highs in Lows *Fog light Fix *Pioneer Premier P730 *Sound by Audiobahn *White HVAC Panel *Security via Ungo MS2007 *Elky Mesh Mod
Posts: 668 |
2-very good company Go with which ever pair sound best to you and will be usefull in any future upgrades.
98.5 SVT#6092 of 6535 B/MNB Born on date 5/22/98 Y2K Suzuki GSXR 750 Y/B with 140.6HP
Posts: 76 |
I am looking to get speakers as well and kinda like the crystal's but there is no way I could test them. Since I don't plan on getting a subwoofer, I was thinking of getting the pioneers instead, as they go lower than the crystal's (only based on the frequency range). If someone would say otherwise please let me know.
1996 GL Red Contour, Zetec, ATX K&N Filtercharger,aluminum mesh grill OBX Fog Lamps, Viper alarm FocusSport High Performance 8mm Spark Plug Wire, LEVOC custom ATX shifter Panasonic CQ-FX620U Head Unit, Panasonic CX-DP88 8-disk changer, Infinity Kappa 572.5 Front/Rear JCWhitney 80W Xenon Headlight low beams CEG sticker, Bridgestone Potenza RE950 Magnaflow SS Race Series#14830 & Resonator #10424
Posts: 4,319 |
I say otherwise. Take it from me. The Crystals rock....
1991 GVR4 Lots of mods done.
Posts: 1,032 |
Get out and listen to them!!! That should make your decision simple. Everyone has got different ears. Call around to your local shops and see if they've got 'em set up for an audition. Just to throw something else out there, I really love my Focals.
1999 SVT #900/2760 Born on 1-20-99 Silver Frost/Midnight Blue A few aesthetic and audio mods
Posts: 869 |
What model in focals, and how much do they cost?
Posts: 8,142 |
You can get a 6.5" component set from www.zalytron.com for 129.00. The only drawback is you have to assemble the crossovers. Great speakers though.
Posts: 869 |
From this page? http://www.zalytron.com/autosale.htm looking there I have no idea which one is the 6.5" component set, but could I use the built in crossover in my HU? Does the cross over just filter out lower frequencies, cause my HU can do that... Is this what you are talking about: "Do to the great response to the Focal car audio systems listed below, we would like to offer an upgraded system. The Focal 165ZLT is the woofer used in the 165E2 system, we will add a TN46(better) tweeter and a Focal 12db crossover and sell this system for $129.00. When you call ask for the upgrade special. " Can anyone translate this into english for me Can you drop in the 6.5" in the door panel, then mount the tweeter where you want, or do you have to build a wood plate to fit the 6.5. I am by no means a car audio guru, I am in the process of searching thru focal posts so please help me.
Posts: 1,050 |
If they all sound the same, go with the cheapest. But I have heard great things about the Audiobahn line, their new subs and amps are frickin amazing. You may want to expand later and it would suck if your fronts were cheap. However, I would go with bigger speakers than those AB plate speakers, see if they have a 5x7 or 6.5 coaxes, or 6.5 separates if they got it.
warmonger
You can call me anything you like as long as it's nice.(all lies accepted) 99 Silver Frost SVT. #226 of 2760 Engine: 3.0 power! Unique Stuff: Sunroof control module (#1 of 9) Car Audio: Loaded and loud! Check them out at http://home.earthlink.net/~twilson1726
Posts: 4,585 |
Originally posted by bkent: "Do to the great response to the Focal car audio systems listed below, we would like to offer an upgraded system. The Focal 165ZLT is the woofer used in the 165E2 system, we will add a TN46(better) tweeter and a Focal 12db crossover and sell this system for $129.00. When you call ask for the upgrade special."
This is what Dave was talking about. In laymens terms, ask for the upgrade special if you want the Focal set for $129. As for the crossover, your HU one isn't the right one. The HU one is just for sub vs. rest, like around 80-100Hz range. The crossover w/ the kit (or any components) splits the correct signals to the tweeter and the mid-range supplied. If you do not want to build the crossover in this kit with the supplied caps & inductors, then these can be used. No, the Focals will not simply drop in. An adapter must be used from the 6x8 to 6.5" round. Most people make their own, but some use a Metra adapter.
