#1049669 09/12/04 07:37 PM
I have the 3-2 air bag code. is there a fix for this or do I have to take this to the dealer?
1995 Mercury Mystique GS 2.5L V6 Mods include duct tape holding up various parts, super glue holding together others, and trunk aquarium mod( with all the water in there goldfish came naturally)
#1049670 09/13/04 01:15 AM
-Ken V. 1998.5 SE Praire Tan Zetec ATX psycho_bass@hotmail.com Roush springs Roush rear sway bar BAT struts 17" Millie Miglia HT3 and a ton of subtle asthetic mods
#1049671 09/13/04 01:56 AM
Z
Z
I think I had this problem when my battery was on its way out.
How old is your battery? May want to get it tested at Autozone, or something like that.
Have you had any problems with the battery? Any starting issues?
- Zack WANTED: T-Red HEATED Side Mirrors FOR SALE: 4 14" Alum Alloys and Nearly New Avid H4s Tires w/ Center Caps 2000 T-Red SVT 1995 LX V6 MTX (RIP)
#1049672 10/10/04 08:34 PM
I have already seen the code list, thanks. And i did read read about the battery and replaced it to no effect. I have checked the fuses and what lines I could reach. Everything seems in order.
#1049673 10/12/04 08:38 PM
Code 32 is a driver's side air bag circuit with high resistance. Does the horn work? Does the cruise control work? If no on both accounts, the clockspring is probably bad. If the horn and cruise work, the clockspring may still be bad, but you'll need to check the other connectors as well. If necessary, you can check the resistance of the air bag itself with a dvom. Resistance should be about 2 ohms. Do this check last, because if it is bad (or if you blow it up) a replacement unit is around $600. Better to remove the bulb and wear your seatbelt.
