Page 2 of 2 1 2
#1047488 09/27/04 11:54 PM
Paul
With the engine off and the key on the batt light should light. It could be a bad bulb (likely) or a broken wire. If you checked everything and you still have no charge (>13volts with the engine running) then the ALT is bad.
jeff
April
As long as the conductors are not corroded you can tape them up and you should be OK. Any corrosion will reduce the capacity of the wire causing heat and the possibility of fire.
jeff
have you fixed your ford lately?
#1047489 09/28/04 12:14 AM
chinsta Offline OP
Jeff,
Could the bad/blown out battery light/bulb cause the problem??
Paul
#1047490 09/28/04 04:30 AM
It sounds like a trip to the auto electrical shop.
#1047491 09/29/04 03:09 PM
A trip to the dealership found my problem: the alternator wire was frayed and shorting against the body in an area I couldn't hope to see. I did get a bit of respect from the advisor, though; changing the alt. on the ground without a hoist.
Black/tan early '98 Contour SE Sport; dead-dead-deadsky (gone, split, outta here, afterlife kids) '05 Pontiac Sunfire; 2.2L Ecotec, ATX, well-equipped Mom also has black/tan '98 Mystique LS; V6, ATX, Alpine CD deck
Page 2 of 2 1 2
