After much pressure from CEG'ers i decided not to replace my cat(p0420) and decided to gut them. Well now I get p0136. I followed the how to from here somewhere where there is a cougar been done with the circuit diagram within the instructions.
Any ideas before i swap the front and rear sensors and check my circuit?
2000 Contour SE Sport 2.5
If your getting a P0136 Downstream Heated Oxygen Sensor circuit fault - Bank No. 1.
Then your Mil Eliminators aren't working.
Do you mean this How to?
I understand the logic for people to make there own Mil Eliminators, but why not just spend a
couple of extra bucks and get some that you know will work..
i.e. http://www.ponyexpressperformance.com/mileliminators.html
1996 2.5LT V6 Contour ATX My Tour+help/info pics E0 rims, Gutted Pre-Cats,CTA Custom Exhaust & Intake, Diablo Chip.
Well i fixed it last night. I had the wrong capacitor. it was a .5uF instead of the 1uF. I made them myself since I have all the parts here at work. I used surface mount resistors and caps. My circuit is about the size of a dime. I think the wires are thicker than the parts used. Any ways it's fixed. I should have verified my circuit before in installed it.
thanks for the links.
Glad you got it fixed.
Kind of easy problem as your code was for an O2 that should've been reading ok.....
