#1047190 09/09/04 03:17 PM
Solarus Offline OP
Hey all,
I'm a newbie to the contour/mystique family but I ahve a problem. My rear window switches dont work. They work fine from the master switch (no the lock isnt on) but not at the doors. Anyone face this problem? Something I can do to fix it? I just dont like having things not work on me like that.
Thanks!
-Rich
95 Mystique v6 atx
86 Toytoa MR2 NA
84 Toyota Celica drifter
#1047191 09/09/04 06:40 PM
I assume that the back windows do not go up or down with the rear switches. If so, pop out the front drivers side door switches and check to see if the connectors are fully seated. Then check the lock out switch, it is probably bad.
Try lowering the rear windows with the front switch then bring them up with the rear. You can also check to see if the rear switches are illuminated (if equipped) this will verify that 12v is getting to the door switch.
jeff
have you fixed your ford lately?
#1047192 09/09/04 07:10 PM
If you end up needing any switches, PM me I have abunch laying around
Jonathan
Jonathan
#1047193 09/09/04 07:17 PM
Once you have the switches out you could always put some silicone conductive grease on the connectors to make sure you have good contact and aren't getting moisture in them.
"A job will always take TWICE the time you think you need."
#1047194 09/09/04 07:37 PM
F
F
jeff
I would start at the master door switch(drivers side), get a good test light, to verify that the rear windows are not getting power. The fact that both windows went out, I would assume the master switch to be faulty, or bad conection.
1998.5, Black, SVT #5638 of 6535 "Lead, Follow, or get the hell out the way" http://members.cardomain.com/19contour98
#1047195 09/09/04 10:10 PM
no the lock isnt on
Try sliding the lockout to the other position and then try the window switch. The pic on my lockout switch makes me think it is locked when it is not and vice versa.
#1047196 09/13/04 03:23 PM
Solarus Offline OP
I've done that many times
#1047197 09/14/04 01:55 AM
Do the rear windows go down from the drivers control?
Both of my rear switches broke. I just replaced the switches and problem solved.
2000 WS6 Convertible A4 13.11 @ 107.5 with a lid, Ram Air and LTs Gone:95 Mystique LS Young America edition V6, MTX 15.6 @ 91
#1047198 09/15/04 03:27 PM
Solarus Offline OP
Both of them broke at the same time? Thats kinda odd. I will check them on monday when I get the car back, along with the master switch.
thanks guys
