#82936 11/22/01 07:01 AM
TrUjAp Offline OP
What are your guys' opionion on either the memphis 500d or the mtx. Right now im in the market in getting a 500 D but am not to sure where or not i should get the memphis or mtx. Both amps are about the same output and what not, the only major thing is reliablity! If this helps I have 2 mtx 6000 series with 500 watts max power waiting for me. So all your opions would help.
thanks
1997 T-Red Contour
V-6 MTX
Magnaflow custom dual exhuast
SC Cold Air induction
Sony LCD screen with PS 1
Neon interior lights,gauges
Momo shifter knob
SVT E0 Rims
Touring Spoiler
In the means to change the sound system.
#82937 11/23/01 09:11 PM
well i have had my mtx 500 d running my JL W3's for a year now and it still kickin with no problems what soever also barely gets warm and i run it hard. i will reccomend that you install at least 4 ga power wire. hope this helps.
Dave
#82938 11/23/01 09:14 PM
I've had a couple MTX amps as well as some friends/family. Never a single problem and always put out much more than rated power.
They do run very warm, tho. Maybe the class D will take care of the heat issues.
Definately go with 4ga power wire (and ground wire) and allow for pleanty of cooling if you get the MTX.
1999 SVT #900/2760
Born on 1-20-99
Silver Frost/Midnight Blue
A few aesthetic and audio mods
#82939 11/25/01 02:47 AM
TrUjAp Offline OP
Sounds pretty good guys!! But has no one ever dealt with a memphis amp yet?
1997 T-Red Contour
V-6 MTX
Momo shifter knob
SVT E0 Rims
Touring Spoiler
#82940 11/25/01 04:23 AM
W
W
MTX has always made good stuff. I recommend the MTX since you already have MTX amps. That way your amps will all turn on at the same time. Using different amps can sometimes result in the front end or bass coming on out of synch, unless you have a synch output on all amps involved. You could just time both amps as to how long it takes them to turn on if you really want to use a different amp. If its a big deal to you.
warmonger
You can call me anything you like as long as it's nice.(all lies accepted)
99 Silver Frost SVT. #226 of 2760
Engine: 3.0 power!
Unique Stuff: Sunroof control module (#1 of 9)
Car Audio: Loaded and loud!
Check them out at
http://home.earthlink.net/~twilson1726
Moderated by  dnewma04_dup1
