#1047078 09/09/04 12:52 PM
I have a 98 contour SVT 117k miles. Last night my tac started jumping all over the place during normal driving. Now it won't even move (stays on zero). My car revs normal and idles fine. I just had the AIC valve replaced 2 weeks ago. Any suggestions were to start. I have a Hanes manual, but no luck in it. Thanks
LPC
#1047079 09/09/04 01:47 PM
I have an extra one out of a Mystique cluster. If you're interested PM me. I know it won't match but if you'd like to troubleshoot I'll let you have it cheap.
"A job will always take TWICE the time you think you need."
#1047080 09/09/04 05:15 PM
Did you ever replace the gauges/cluster assembly?
[color:"green"]-Matt R
'99 Tropic Green LX, Zetec, ATX
#1047081 09/09/04 07:27 PM
F
F
Find out if it is a mechanical Tach (Cable driven) or electrical.
If mechanical it could be one of Three things.
1) Tach guage (needle) / cable inlet stripped
2) Tach Cable, broken / stripped
3) The tourque/gear reducer on the transmission.
For trouble shooting the guage and the cable, disconect the cable from the trans. and attach a power drill to the cable. Making sure that the drill is rotating the right way, it should register a RPM reading. if you get a reading it is the gear reducer, if no reading, disconect the cable on the guage side and observe the cable ending, look for signs of stripping, and observe the rotation from the drill. If the cable is rotating and the cable end looks good your guage is the problem. If no cable rotation, cable is your problem.
In all of the Mechanical Speedo/Tach problems I've done it usually turns out to be the cable, or the gear reducer, but never rule out the tach.
As for the electric controled tach.......Well good luck, I would need a good electric troubleshooting manual , a good test light / multi-meter, a six pack of a good barley beverage , and a glossery of good swear words .
Good luck
1998.5, Black, SVT #5638 of 6535 "Lead, Follow, or get the hell out the way" http://members.cardomain.com/19contour98
#1047082 09/10/04 01:20 AM
Thanks for the starting point FlynLow. I have not replaced the gages, but I was going to remove them to replace some light bulbs. Will I need to anyway to proform those steps?
I'll start Fri. got some time. Let you guys know how it goes.
