#1045229 09/07/04 09:00 PM
Stupid question maybe, but I will ask it anyway. What size bolts do I need for my rear license plate holes? They look a bit stretched out from the previous owner. I went to several parts stores and have tried many sizes. Everything else I have found in the FAQ and by searchinmg th forums. Thank you.
1995 Mercury Mystique GS 2.5L V6 Mods include duct tape holding up various parts, super glue holding together others, and trunk aquarium mod( with all the water in there goldfish came naturally)
#1045230 09/07/04 09:15 PM
pre 98 had a hidden nut molded into plastic frame. those nuts normally seize to the bolts and then break loose in the frame. that's most likely what you have. I drilled a hole and mounted the plate w/ stainless steel bolts and nuts. w/ washers and all it was water tight. worked w/ no drama for four years and two license plates
#1045231 09/08/04 03:52 AM
If they have not been modified they are metric. I don't know the size but had no trouble matching them up when I replaced them a few years ago.
Put a little bit of anti-sieze on them and you will not likely have the dreaded siezed bolts when you need to remove them sometime in the future.
