#1044479 09/06/04 08:39 PM
I have a 1998 Contour SE w/2.5L V6 Engine with approx. 110,000 miles on it. The problem I am having is while i am driving my temp gauge goes all the way into the red. When I got home i checked the coolant level and it was fine. i also checked under the car for leaks but nothing was coming out. Thinking it was the thermostat I replaced it, but the problem still occurs. my low coolant light does come on when i start the car, but goes away after about 2-3 minutes, and cool air comes out when my heater is on even when the temp guage is above normal. Could the problem be the water pump? Thanks for any help.
#1044480 09/06/04 08:45 PM
check your radiator hoses. i would say you have no leaks if the coolant is fine but the hoses might have a clog. this happened on my mustang but before i could react a hose burst. if the coolant is flowing fine make sure your fan is cutting on.
05 Chevy Colorado z71 4x4 *for sale* 97 Honda Accord 4door track whore *12.9 N/A* (blown and wrecked) 97 Honda Accord 4 door 03 Eclipse GS
#1044481 09/06/04 08:55 PM
Yes my fans turn on normally, should i check every hose in my cooling system?
#1044482 09/06/04 08:56 PM
For the coolant light, fill the resevoir tank just above the max mark
and you'll never get a coolant low light again.
No heat out of the heater is the number 1 diagnosis for water pump failure.
Don't drive the car until the water pump is fixed!
1996 2.5LT V6 Contour ATX My Tour+help/info pics E0 rims, Gutted Pre-Cats,CTA Custom Exhaust & Intake, Diablo Chip.
#1044483 09/07/04 01:55 AM
N
N
Don't drive the car. Your waterpump is gone. If you have no heat coming out of the vents even after warmed up that's the first sign of a bad (broken) waterpump.
Do not drive till it's fixed or you'll need more than a new pump!
#1044484 09/07/04 05:21 AM
just the inlet and outlet pipes from the radiator usually get clogged. let it cool totally down. the fluid in resevoir should read cold. start and leave, coolant should rise. if coolant does not change replace water pump impellar. or do the heat check. i say do both.
#1044485 09/07/04 12:07 PM
The water pump impeller has failed. Quit screwing around and get it replaced. Make sure you get all the pieces of the broken impeller out of the system.
As already said, DO NOT DRIVE THE CAR! Engines are expensive.
Steve
#1044486 09/07/04 03:43 PM
thanks everyone, i will get the water pump replaced asap. do you know how much it might cost?
#1044487 09/07/04 04:42 PM
N
N
DIY
Buy new pump & gasket and belt
Remove plastic front engine cover
Loosen tensioner on waterpump belt & remove belt. (Push tensioner down to loosen slack on belt. Then belt just pops off)
Remove battery
Remove bolts holding waterpump to block (remember which ones are the short ones) A good socket extension helps here.
Pry waterump apart. The part you bought will be the outer piece. The inner piece is just a case part. Have bucket under this section as coolant will come out,not a lot but enough to make a mess
Remove any impeller pieces you can with your fingers
Reverse to put new impeller back on. Add a little coolant to overflow to make up lost amount and then go get the system flushed to remove any smaller pieces of impeller which may escaped your fingers
Very easy to DIY.
#1044488 09/07/04 04:57 PM
thanks, it sounds easy enough, how much does the part go for?
