#1042419 09/03/04 05:12 PM
H
H
My car is in the shop and the mechanic is recommending a Delco 417 that sells for $80. He says I need a battery with around 800 amps. Are there cheaper ones that will work?
Thanks
negative you need one with 540 to 650 CCA, according to the haynes manual i am looking at, so tell him not to get you that one unless you want it because you can always go with something a little less powerful
98.5 Black SE ATX S&B filter, SVT MAF, optimized SVT TB, mesh grille, removed orange reflectors, painted rear reflector, gutted pre-cats, optimized SVT LIM, 19lb injectors, resonator removed cant afford an svt but lookin for 1 in nc
The Motorcraft replacement is a 650 CCA battery FWIW.
Depends on the accessories you have in your car... if you have a huge stereo, you will need more amperage. with 1000 watt stereo, I had to have a 1050 CA batt in my Celica.
Though it can be nice to have a bigger better battery. My diehard is still good after numerous times of letting it completely drain. Was able to start it once after leaving the headlights on for like 2 to 3 hours.
H
H
Thanks all!!
Kremithefrog, what were the amps on the Diehard?
I just bought one from O'Reiley's for $59. It has 815 cranking Amps (660 CCA).It is a little bit wider that stock, but fits fine.
TR
"Eagles may soar high, but weasels don't get sucked into jet engines."
