Posts: 2,779 |
Originally posted by DemonSVT: Originally posted by gearhead98: what about new head bolts, aren't those TTY??
Yes they are.
To be honest he should already know what he needs for a swap before he starts it.
All this information is readily available.
Oh you didn't see his first post?!
It was something along the lines of....
Hey I just bought this nifty 3L block and I figured it might fit in my car so anybody have any ideas?
j/k, have fun. I wish I could go this route sometime, that's if my car would like to start at least 99% of the time.
Posts: 829 |
Call me kooky, but are we forgetting that the 98 is Fuel Return and the new block is Returnless? I had to had a fuel rail fab'd for the return line. It still scares me a bit as it is only soldered and heat painted... Let me know if there is an easy way around this...
SVT Parts For Sale!PM Me.
2006 M6 Cyclone Gray GTO
1995 Mazda Protege Commuter Special
93 FXDWG Dyna Wide Glide
I'm A TROLL Now!~
Posts: 3,570 |
Originally posted by Rev. Po-Jay: Call me kooky, but are we forgetting that the 98 is Fuel Return and the new block is Returnless? I had to had a fuel rail fab'd for the return line. It still scares me a bit as it is only soldered and heat painted... Let me know if there is an easy way around this...
No, this doesnt matter. He is buying a new 3L shortblock, which is basicly an engine without heads. He's using his 2.5L components from the heads, up.
Posts: 28 |
Yes they are.
Actually you are right, and that is exactly what I am trying to do.  I have been doing a lot of research on this and you guys have been confirming most of what I believed to be true.
Posts: 829 |
Originally posted by rkneeshaw3.0: Originally posted by Rev. Po-Jay: Call me kooky, but are we forgetting that the 98 is Fuel Return and the new block is Returnless? I had to had a fuel rail fab'd for the return line. It still scares me a bit as it is only soldered and heat painted... Let me know if there is an easy way around this...
Ahh, I missed the "shortblock" peice. Thanks!
I'm A TROLL Now!~
Posts: 28 |
Just wanted to report back on the noise I was hearing from the engine area. After completely removing the engine and taking off the oil pan, I was able to find the source of my noise. I could grab the #1 cylinder rod cap and move the rod back and forth on the crankshaft and basically dulpicate the noise. I pulled the oil screen off and found the entire screen packed with what looked to be bearing pieces. I am already most of the way through installing the 4F1Z-6009-BA short block from Ford. Everything seems to be going fairly smooth, the NECO Forum with - How To 3.0L Hybrid Overview was a huge help. The example used is a 2000 engine and there are some differences in the 2004 engine I am using. I have been taking pictures right along and plan to start a new thread with more details and part numbers. Thanks again for all the help. Marty 98 SVT 3.0L ( almost )
