Posts: 725 |
I�m on number 6 now and probably the 7th will be going in this weekend. Front driver side bearing lasts at the most one year and sometimes up to 3-4 months, last one replaced this spring.
I've done wheel aligns; replaced the hub assembly, ball joints and half shaft and I�m still throwing wheel bearings.
I�m running out of patience and I�m going to replace the spindle and hub.
From what I�ve been told that the spindle is indestructible but it�s the only thing that I can think of that I haven�t replaced on the driver side of the car.
Another thing I noticed is abnormal wear on the driver side tire, the inside of the tire is wearing faster than the rest.
Any suggestions about what my problem could be�
95 SE MTX
DH UIM, 65mm TB, SC CAI, Quaife, Centerforce, Fidanza, UR Pulley, F/R Strut Braces, Cross Drilled Rotors, S.S. Brake Hoses, 18" Enkei RS5, SVT Engine Mounts+Inserts, MSDS & y-pipe, Trubendz resonated exhaust & MagnaFlow cat
Posts: 2 |
Bummer.... could be more expensive I guess but at the rate you're going I guess it's adding up pretty fast  Only things that come to mind are camber, toe-in or out and maybe loose steering parts on that side. Had an alignment check lately? .02
1998 Silver Frosty SVT
K&N, Yokohama AVS ES100 205/55-16
Midnight Blue (with those ^%#$& cupholders)
5 year warrantied Alternator
previously:
1991 SHO+ Emerald Green with the fiberglass hood
Posts: 468 |
if you are getting tire wear after an alignment then they are not putting it to spec. May need a camber plate installed. Perhaps from worn out suspension - they get it as close as possibl (but out of spec). Camber plate should allow them to get it right to specs. Get the printout from the alignment shop and then let us know the numbers. Im sure the correct ones should be on the board here somewhere.
2005 Focus ST
Posts: 725 |
replaced spindle, hub, bearing, and got an alignment. took it for a test drive and discovered that the front passener side wheel bearing is going too. it had no play in the tire when it was jacked up but makes a humming sound under hard left turns, too bad we couldn't hear it before we replaced the driver side bearing. now i have to wait till next weekend for the shop to get another wheel bearing and get me in again. small town mechanics don't carry parts for a car like mine plus i can only get my car in on saturdays. well my wheel bearing count is at: 7 on LF, 1 on RR, and coming up 1 for RF. 9 bearing in 6 years i must have some kind of a record for that on this site.
95 SE MTX
Posts: 21,197 |
Wrong wheel offset will create bearing problems.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 725 |
Originally posted by todras: Wrong wheel offset will create bearing problems.
i had the problem with my stock wheels for 5 years before i got the 18"s last summer.
95 SE MTX
Posts: 2,975 |
So it's turn left and noise/grinding = right bearing and reverse for the left?
1992 Ford Escort LX-E
-Tracer LTS spoiler
-GT Grille
Posts: 725 |
Yah I know but we couldn't hear the right bearing before, the left was really loud. On top of that I had no exhaust left underneath the car before we replaced the bearing. We only went off up/down wheel play and the history of the left front side. The good thing is that front left has no more play after spindle/hub/bearing replacement, which usually is back within 2 weeks after repairs and the noise is back within couple of months. So i hope that the spindle was the problem and it is fixed now.
95 SE MTX
Posts: 42 |
I've replaced 5 front bearings and 4 spindles. The spindles wear into an oval where the balljoint fits in. I even had one balljoint pull out of the spindle at low speed ( Thank God ). I fitted the last 2 bearings myself, with a press at work, to see if it was sloppy mechanics doing me in. You absolutely cannot press on the inner race when driving them into the spindle.
96LXV6 heavily un-modded due to family addition.
87Renault GTA convertible, chopped springs, Ford Premium Sound, but otherwise stock.
