Posts: 26 |
well this morning when i parked, i pulled up on my ebrake and the handle went all the way to the back. now my ebrake doesn't work at all. the brake light in the instrument cluster goes on, but the brake is not engaged. how much will this cost to fix, or is it something i could do?
99 Amazon Green/Tan CSVT 66k Miles
* Tinted Windows
[img]http://img.villagephotos.com/p/2004-12/915133/grn99toursmall2[1]_23491043.jpg[/img]
Posts: 1,605 |
Sounds like the cable might have came off or snapped... Jack up the rear end of your car, take the back wheels off and check the cables! They aren't that hard to replace, i put the updated ones with the release spring on my SE, took maybe an hour at the most.
#3162 of 6535
98 SVT Silver frost
Viper Responder 791 w/ 2way remote start
Let the modding begin!
Posts: 26 |
where does it connect to the rear wheels? the only jack i have is the one in the trunk. will i be able to reach it with that jack? how much do i expect a new cable to cost and is this a common problem? what tools do i need?
thanks
* Tinted Windows
Posts: 2,725 |
Originally posted by Hubes914: where does it connect to the rear wheels. the only jack i have is the one the trunk? thanks
That isnt safe to do work under the car using that one, the jack plus two stands is like $40 at Sears, works great thats what I use.
I'll take a picture tomorrow for you and show you, that is if it doesnt rain here. Anyways cables rust overtime and get worn and do sometimes brake. My e-brake hasnt worked in well over a year, if I use it it gets stuck so I just dont use it, then again I have a automatic so no need to.
Posts: 26 |
i remember i got 2 ramps. a jack and stands is only like $30 together? damn i might go buy them. always good to have around the garage. thanks for the pics. i appreciate it.
* Tinted Windows
Posts: 26 |
how come it seems like a few posts went missing in this thread? anyways tonight i took off my console to take a qucik peak around and i noticed a black cable coming from the floor up to where the ebrake lever is. this cable was not attached and frayed at the end. is this cable supposed to be frayed? is this cable supposed to be attached? how easy will this to be replace myself?
i got a jack and jack stands for like $30 at walmart. 3 ton "mack" jackstands and a 2 ton "mack" jack. i will take a few pics of the cable tomorrow.
* Tinted Windows
Posts: 26 |
ok here are some pics of the ebrake cable. tell me what you guys think.
* Tinted Windows
Posts: 137 |
I have not looked at my contour e-brake but most have either a bolt on the end of the cable (so you can tighten it) or the end is molded into a little chunk of lead to allow you to put it in a slot and hole, like bicycle brake cables.
Most likely you need to replace the cable. I would say you definitely need to except I have not looked at a contour setup.
Good luck Paul
1998 Contour SVT Black w/ Blue interior
Torsen LSD updated shiftforks
Lightened Flywheel, HD Drivelines
Optimized Thottle Body
2003 3.0L engine upgrade (Soon to be)
Posts: 26 |
can anyone take a picture of where a working e brake cable would go into, the broken one in my pics above don't give me any clue to where i would havce to insert my new one? i am a visual man and need to see where it goes in order to fix it. anyone know any good place to buy the cable from? thanks
* Tinted Windows
Posts: 1,012 |
Originally posted by Hubes914: ok here are some pics of the ebrake cable. tell me what you guys think.
Not related, I know, but what is that silver box in front of the ebrake?
