Posts: 28 |
WHere are throttle bodies located...I know I know check mods/parts..Could someone just tell me a good one and where to get it??? Is it good to get a 75mm MAF and a throttle body???
Posts: 1,145 |
nope unless you are running HIGHLY modified svt then no there is no need for those, your best bet is to optimize your current throttle body
98.5 Black SE ATX
Posts: 28 |
so what about just getting a 75mm MAF and then run new air inlet???
Posts: 1,145 |
nope your stock maf is good enough unless you are running atleast a 3L, a new air inlet?? what do you mean??
98.5 Black SE ATX
Posts: 28 |
They make thoses chrome air inlets...Do they give better flow??? Or just for looks???
Posts: 1,145 |
Oh the aluminumum air intake pipe, they help out some as they do not neck down inside like the stock rubber tube does, they also help since they are smooth and not bumpy inside (the up and down thing)
98.5 Black SE ATX
Posts: 1,746 |
Originally posted by SVT4321: ...I know I know check mods/parts..
If you know, why are you asking? This has been covered SO many times. Quit being lazy.
Posts: 7,025 |
Bottom line: Going to a bigger TB on the near stock 2.5L is a waste of money. Optimize the one you have. IMO a 75mm MAF is a waste too since your not even going to outflow the one you have. Its good for about 300 hp. Yes, the Pro M would probably flow better, but I would say the hp gains are minimal. Btw, there is a thread stickied at the top of this branch, discussing this very issue since its been discussed so much.
Jim Hahn
364 whp, 410 wtq @ 4,700 rpm
Posts: 3,570 |
A larger MAF on SVT's even barely makes any gains. I think Demon is the only one to get any gains with it on his extremely highly modified N/A 3L. Pointless on anything less.
Learned patience the hard way
Posts: 2,454 |
The only use for a larger MAF on an SVT is if you're running out of voltage due to increased need for air such as turbo or S/C. I'm going to upgrade to a 90mm here shortly as I think my 75 pro-m is holding me back.
Rick
Owner of 00 #1611 Silver (Totalled) 98.5 T-Red SVT #6180
Buckshot77@msn.com
Misc 3L parts for sale
