Hitman, Hitman, Hitman will u ever learn?
Back to the original question:
P1131 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 1.
P1151 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 2.
these codes do not indicate bad HEGO necessarily, could it be that you actually are running lean due to something else? like a leak or bad fuel pump?
