Posts: 6 |
What kind of fog light bulbs can I put in my 98 svt contour factor fog light holes and also what is the part number for the kind of bulb I need??
Posts: 2,779 |
Posts: 7,025 |
Originally posted by JonnySVT: 1. 893 2. 893.....
I think you meant to put 885 for #2.
Jim Hahn
364 whp, 410 wtq @ 4,700 rpm
Posts: 21,653 |
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 2,779 |
Originally posted by beyondloadedSE: Originally posted by JonnySVT: 1. 893 2. 893.....
Actually it should be for #1. 893 is the correct bulb, but you can also use 885. I was just poking fun at his post.
Posts: 314 |
893 is stock, 885 is a little brighter but due to increased power, but some ppl have melted their lenses. I have run 885s with no problems for years. FWIW.
Brian 99 SVT
Posts: 3,570 |
Even 893's have melted my lenses, no way I'm going 885  But diferent strokes for different folks
Posts: 1,145 |
you can use 880's like me, which is stupid because they are lower power, i just cant find bright white ones in either 893 or 885 if i could i would use those, the 880's i have are silverstar and match my headlights
98.5 Black SE ATX
Posts: 3,570 |
Nokya makes some 893's in a white. It's about the white color of PIAA's, looks exactly the same color temp as my SilverStars. Do a froogle search, they're fairly cheap for being white bulbs too. I've had mine in for almost a year now, without them burning out (knock on wood)
Also, SilverStars are now available in a 893 bulb
Posts: 1,145 |
silverstars are made in 893s now?? cool gotta go find some then
98.5 Black SE ATX
