With the Dayton DVC.
You can get away with
sealed: .67
ported: .67
Port: Dual flared 4inch port 12.75 inches long.
I would sugest that you use polyfill on the sealed side because it will smooth out a peak at about 90 hz. If you want to go without, it probably won't be real audible.
I wouldn't skip the egg crate foam or fiberglass insulation on the ported side though.
