Posts: 30 |
99 Ford Countour 2.0 temp normale on highway but overheats on streets. Notice cooling fan wasnt kicking on. I have a Hayes manuel but it has the wrong diagram for the engine relay. Does anyone know which relays for the cooling fan are the high and low  ?
99' royal purple contour
Posts: 5,143 |
the Sending unit in the Zetec's are kind of wierd... MOST of them are telling you its at the top of the heat spectrum when its really closer to the middle. Next chance you get, start your car up and let it idle and wait till it goes to about the "L" on normal. and listen for the fan to kick on... if it does, then your sending unit is telling you the wrong reading in the cluster. if the temp continues to rise and the fan does not kick on... Then I would say replace your Thermostat.. its pretty easy.
Edit: does turning the AC or Defroster on turn on the fan? and does it make the temp stay down?
98 Corolla LE 1.8L DOHC 1ZZFE
TEIN H.Tech Springs
Tokico HP series Struts
Short ram air intake
Tsudo Axel Back Exhaust
Posts: 1,788 |
The low speed fan resistor is a common failure.
I recall it having been discussed in the past. Perhaps you can locate these discussions by searching around.
Steve
89 Taurus SHO - 246K miles
94 SHO ATX - 190K
Posts: 30 |
where is this resister found???do you have a picture?
Posts: 392 |
I have the diagram of the electrical cooling system for a contour 99 2.0 with A/C and the battery junction box pictures that shows you exactly where are your two relay and the resistor but i don't know how to send pictures. So e-mail me if you want the information or tell me how to post them.
Nic.
Contour 99 MTX V6 fully loaded, stock with 110000km. Illuminated sunroof switch. About to do the mystique rear dome light conversion with eyeball dome light.
Posts: 23 |
Would a 96 zetec also have this sending unit.If so where would it be located?I dont want to hijack this post but I have the same problem.My guage goes all the way to the L then the fan kicks in and it just stays there it doesnt go down.I was thinking it could be the coolant temp sensor.
Posts: 1,459 |
Originally posted by vladmire: where is this resister found???do you have a picture?
It's near the bottom of the radiator, on the driver's side corner, facing toward the engine. You can trace it by locating the motor on the cooling fan, and then following the wires backward.
95 Mystique Zetec, MTX
2000 Taurus SEL 3.0L Duratec
1994 Crown Victoria LX 4.6 V8
1993 Chevy Silverado 4.3 V6
Posts: 1,085 |
Both cars have 180* thermostats. The temp gauge points straight up BUT every so often (Small hill) the needle rockets towards hot. The engine coolant as not reached the fan on temp(fairly high). As a test I turn on the A/C(starts the cooling fan automaticly) and I observe the temp needle as it returns to straight up. SO....everything is operating according to Ford spec. Sometime one has to just look away....
2012 Lotus Evora
95 Mystique MTX - GONE 395,000 Kms
--------- Both Zetecs
'97 Contour Mtx - stock - GONE
Posts: 30 |
Eh nick on the cooling fan diagram the dual pressure switch N76 is that the a/c switch? do you know of any specs for the switch and where is the ect shouldn't that be apart of the diagram
Posts: 392 |
Honestly i'm not sure, i can have u the imformation on the connector and the switch, in maybe a few days (1-2days) And i don't anymore have my access to the information, i've kick out from my job and my account has been suspended. I'll give you the information soon if you still need em.
