#1034945 08/26/04 05:15 AM
I've been having problems with my idle lately. When just sitting, it will surge between 1000 and 1500 RPM. I noticed lately, that if I leave my A/C on, even just on low, it will idle smoothly, although a bit high - somewhere around 1100 RPM. I DO have a CEL, P0171 - Bank 1 Lean. I have already replaced EGR valve, IAC valve, PCV valve, plugs, wires, MAF sensor, both 02 sensors, ECT sensor, TPS, and have checked battery and alternator, both good.
What I was wondering - Is there anything that gets bypassed when the A/C is turned on? Does anything open or close (EGR, IAC, etc.)? Are there any relays that might cause this? Advance says there's an EGR Valve position sensor on my car. I've never heard of this?
Thanks for any help!
Jonathan '96 Contour Zetec MTX 208,XXX miles
#1034946 08/26/04 05:20 AM
H
H
I don't know about the A/C, but it sounds like you have a vacuum leak. It could be a gasket that's leaking. Have you tested for a leak around the manifold?
#1034947 08/27/04 03:03 PM
Yea, I've been through numerous cans of WD-40, Carb Cleaner, etc. as well as hours of looking and feeling for anything that might be leaking. Nothing as of this point.
#1034948 08/27/04 03:12 PM
I
I
Any updates on this ???
I have same problem on my 4 cyl 96 mystique.
Idle is at 1100 rpms, then 1 second later, goes down to 800, and it keeps doing this ... Up and down, up and down, very regular pattern. Sometime it will die on me at a stop light.
Runs much smoother if I turn the AC on. Idles at 1000-1100 rpms and it pretty smooth.
No CEL.
I suspect a vacuum leak at the PCV but not too sure. I might look this week-end.
Could a misadjusted TPS do that ?
Any ideas.
iougs-
Mercury Mystique 96 2.0L Ford Contour 97 2.0L Mazda RX-7 87 Sport 1.3L The Mazda RX-7 86-88 technical page
#1034949 08/27/04 08:51 PM
I have similar problems and I am suspecting Throttle position sensor. not too expensive I will be purchasing it soon..
#1034950 08/28/04 04:54 AM
Not as of yet. I just put in a new Camshaft Position Sensor, with no luck. A buddy of mine said it sounded like it was missing. He's an old Chevy guy, but missing is still missing. I'm going to be looking closely at Coil Pack/Plugs next. I've got brand new plugs in it - Autolite Double Platinums, as well as the Autolite Professional or whatever plug wires. I'll update as I find anything new!
#1034951 08/30/04 01:55 PM
I
I
The more I think about it the more I think it is a vacuum leak ... Engine revs up, ECU sees the signal from TPS saying no throttle and cuts fuel as if decelerating, rpms go down, and the cycle keeps going and going.
One more observation:
this up and down thing does not happen when engine is fully hot. When engine is hot, idle seems to be very smooth even with electrical accessories on.
I dont't know if the original poster's idle smoothes out when the engine is hot though.
iougs-
#1034952 08/30/04 07:17 PM
9
I have been trolling the boards for awhile and have found that people have been having idleing troubles with the autolite's double platinums. Maybe a semi-cheap fix would be to buy different plugs. Just a thought!
Assault Towers Wakeboard towers and accessories www.assaulttowers.com
