Posts: 35 |
Ok well i turned out of my road and i hear a pop. so when i get back to my house i see the fuse is blown so i put another fuse in and 2 seconds later it blew it again. so i checked everything all the wiring for my stereo and everything. the fuse was to the courtesy lights but my sterio dosent work either. neither does my dome lights. i have a 95 countour se with the 2.5 liter duratech. anyone got ne suggestions?
plz help
1995 Ford Contour SE
Champaigne
1 10" JBL GT100 dual voice w/custom box
Knauberized
207,219 and counting
Posts: 4 |
Got kids?
I had the same problem a few years ago. The fuse for all that stuff would blow, I troubleshoot, find nothing wrong, replace the fuse. It'd work for a while. Finally discovered that my two year old was having fun putting change into the cassete slot on the radio. It'd work until I hit a good bump and then the change in the radio would bounce enough to short it out.
95 LX ATX w/
98 SVT eng,springs & rear swaybar, 2K SVT pipes
Posts: 5,143 |
judging by the sound of his name... I would say he doesnt have kids... Maybe a little to young...
98 Corolla LE 1.8L DOHC 1ZZFE
TEIN H.Tech Springs
Tokico HP series Struts
Short ram air intake
Tsudo Axel Back Exhaust
Posts: 35 |
Well yes i dont have kids im only 16 but no to the change part cuz i put a cd player in the car. and its all wired correctly and nothing is grounded. so i figured it could be something else. ne more suggestions.
Champaigne
Knauberized
Posts: 6,910 |
as I recal I blew the fuse when I ran a new ground for my radio. make sure your ground is good
- 95 Mystique LS - Zetec/5spd
Posts: 3,065 |
Take the dome light cover off. Then take the whole unit off. There are metal clips that kinda hold the blubs in. Put electircal tape around these, and then repalce the fuse. If those clips are jolted they will short out when they touch the metal in the roof. I had the same symptoms when I changed those bulbs. I took the clips off completely, and it didn't hurt anything. Should be a 7.5 amp fuse, IIRC. Good luck  .
