I am building a small 4th order bandpass box for (2) IDQ12 D2 V.2. I found the box demensions and the predicted in car response curves on the ID tech webpage.
Image Dynamics IDQ12 D2 V.2 tech page
When I model the same set up with WinISD I get a totally different plot. Before I start building can someone verify that this will work (and sound good - high output, low transient responce)?
They are predicting in car response including cabin gain. It won't match what you see in WinISD which is simulating anechoic response.
WinISD recommends a box 5 times as big. When modeled the ID designed box looks terrible.
I just plugged the numbers into WinISD and it recommend a slightly smaller box tuned lower. When I plugged in the box specs from ID, it came out as I suspected. There is a big peak around 80 hz and below that it rolls off pretty quickly below that. With cabin gain normally starting somewhere below 80 hz and rising and rising at 12-18 dB per octave in car, you end up with a somewhat flat response that is shown on the IDQ site.
This woofer was not in WinISD list, so I had to punch in the parameters myself. Did you choose one of the woofers from the list?
I tried to plung them in my self as the ones listed were inaccurate. How do youn think this set up will sound. Right now I have the IDQ's in .88 cuft each.
I personally think that you will be happier just leaving them in a sealed enclosure. They are really designed for a sealed enclosure.
I just bought a 1992 325i - I have heard the trunks are incredibly sealed from the cabin and very well dampened. From what I have heard it is hard to get reasonable output unless you port into the cabin. I hoped to use a 4th order with a 5*5 port through the ski pass through into the cabin.
Ahh...i see. In that case, it might be worth a shot. I don't think it would sound bad, and would actually give you an extra 4 or 5 dB in output in the 50-80 hz range.
Whoa - big gain.
How do you think it will effect my power handling? I wanted to go to 600 watts per sub.
The power handling should be hurt by this alignment. If your subs can handle 600 watts, you should be fine.
Moderated by  dnewma04_dup1
