#1026916 08/12/04 11:04 PM
dre1010 Offline OP
My oil pan drain plug is almost to the point where a can't get it off. What is the best plan of action? Does the Fram suredrain work well? Should I just get another 13mm bolt?
#1026917 08/12/04 11:22 PM
W
W
Go to Ford get 'Oversized' drain plug.
2012 Lotus Evora --------- 95 Mystique MTX - GONE 395,000 Kms --------- Both Zetecs '97 Contour Mtx - stock - GONE
#1026918 08/12/04 11:38 PM
I put the Fram suredrain thing on a couple of years ago. I think its great. I had to grind off the barbed fitting that has the plastic hose( original was too long and would not screw in because of the Y pipe)
If your threads are gone, dont know if you want too, but you could try retaaping it to a larger size that the Suredrain comes in, and use loctite to keep the new piece from ever moving.
ad then you'll never have to unscrew this. unless you want to mod the engine.
2000 Contour SE Sport 2.5
#1026919 08/12/04 11:48 PM
If the hex on the drain bolt is stripped replace the bolt. get a correct 6 point wrench to loosen the bolt. 12 point sickets are nice and all but can strip bolts rather easily if they are a crappy brand
06 GMC Sierra 2500HD Dmax/ally 06 Pontiac G6 GT 05 CRF250R FOR SALE 06 KX65 with riding gear $2700 obo
#1026920 08/13/04 01:16 AM
H
H
If the head get a new plug. If the thread then there are aftermarket expandable rubber plugs that satisfactorily solve this frequent problem. Check the oil change accessories aisle in any automotive supply store for the latter.
#1026921 08/13/04 02:22 AM
dre1010 Offline OP
Thanks everyone. I will go to the parts store and get a 6 sided socket, I have twelve.
