#81537 10/16/01 04:29 AM
I
I
my computer is refusing to run WinISD for some unknown reason right now...heres the sub
http://www.eclipse-web.com/product/88000d/88000.html
im looking for what the best sealed enclosure would be, itll be getting 1200-1400watts
thanks,
In
ps if no one can help dont worry I'll try it again after work tommorrow
W
W
Your URL shows 3 different woofers - which one did you have in mind?
Dual voice coil or single?
-Wes
98 SE Sport
I
I
The 88150 is the one Id like to pick up..
ps if you know about cars go to the problems board !
There are two models but both seem to be optimized for a 2 cu ft enclosure.
BTW, that is entirely too much power if you are sending 1200 watts RMS.
uhhhhh
500 watts RMS
1000 watts peak
...and you're sending between 1200-1400?
on a relatively no-name sub???
all i can say is that the box won't matter too much because they will be blown before you hit the first note.
mike
Originally posted by typhoon:
uhhhhh
500 watts RMS
1000 watts peak
mike
Eclipse a no name sub? I don't think so. They are one of the better subs on the market.
I
I
but anyway,...ugh i want a single 15" setup that will take 1200watts..that'll look as nice as the eclipse..
im going to talk to som eclipse owners I think about how much they give theirs..
what about if I use a smaller box to increase power handling..?
And give up deeper bass extension while decreasing sensitivity? What would be the point? You should be able to adjust your gains down to avoid overdriving the sub.
What amp are you using?
1999 SVT #900/2760
Born on 1-20-99
Silver Frost/Midnight Blue
A few aesthetic and audio mods
I
I
im not telling...I know youll say over kill
heh
its an MTX8100D
its very difficult to get the look I want for this install..im having trouble finding the right equiment,,,just need the sub one 15"
Moderated by  dnewma04_dup1
