Posts: 705 |
I will soon be assembling my 3.0L and I was curious because I am using the 2.5L heads with the 3.0L block... Will the timing marks be the same? are there any special instructions or will they line up? Should I get a new 3.0L timing belt or a 2.5L belt? Thanks
-Jeff-
1998 Black SVT
Morette Twin headlight conversion
Street flight turbo kit collecting dust!
Rebuilding my 3.0L
check it out
Posts: 3,570 |
There is no timing belt, there's timing chains. Yes, you need all 2.5L timing components. Be sure to read up on any FAQ's you can find, the NECO boards have a good one.
Timing components include:
chains tentioners guides crank sprockets of course cams.
Once you get all those components, then the timing marks line right up, and the new chains even have a color coded chain link for each spot to line up on.
Posts: 705 |
Is it recomend I rpalce these parts? I already have the cams, but as far as the
Chains Tensioners guides crank sprockets
Should I replace these? What else do you guys recomend I replace during this build up? (besides gaskets) P/N's would be great to so I can contact bill. Thanks a lot guys
-Jeff-
1998 Black SVT
Rebuilding my 3.0L
check it out
Posts: 3,506 |
Everything you need to know is in the 3 liter forum of NECO.
You have to read all 5 FAQ's at the top of there section to get all your answers...majority of the time you do not need to replace these parts unless there damaged.
Lupe
Posts: 411 |
I would replace the chains, for sure. It's been debated as to whether or not the guides and tensioners are "wear" items, so I'll leave that to your best judgement- but definitely get some new timing chains.
-Chuck Dienzo
Black 98.5 E1 SVT
#5022 of 6535
Born on March 16, 1998
"If trees could scream, would we be so cavalier about cutting them down? We might, if they screamed all the time, for no good reason."
Posts: 3,506 |
Well that too is debateable......when i did mine, there was nothing wrong with them...even took them to Apex Motorsports (as well as the heads) to be sure...showed almost no ware what so ever.
Many others have also had no needed to replace them.
Lupe
Posts: 6,760 |
I replaced everything minus the tensioners themselves.
Ryan
Trollin!
Posts: 702 |
Why Take the chance....I'm in the process as well and i'm rebuilding the entire valvetrain except for the cams, and the timing chains/guides/tensioners/etc...If there is a weak link in the system somewhere youll know that it has been replaced...Even though the CSVT is a noninterference motor (meaning that the timing will be retarded if anything in the aforementioned decides to take a s*$t on you in order to not harm the rest of the motor) i dont see why taking a chance would be good idea...??? Trust me, i understand the idea of working on a budget and not being able to afford everything at once...but do it right the first time...I know because ive been w/o my car for five months and its my daily driver...I'm willing to pay for the insurance that my motor is going to stay together when i beat the hell out of it...
CSVT E0 3L
14.5 @ 94mph, Stock Intake, Stock Exhaust minus Resonator, CEL, And Broken Pass. Side CV...Untuned.
Posts: 1,860 |
I replaced the chains and tensioners. Make sure you read the TSB on the chains and count those links!
2001 Lincoln LS8
1994 Lexus GS300
Posts: 496 |
