#1025360 08/11/04 10:36 AM
Strife Offline OP
While my car's in the shop and I'm stuck at home I've been browsing around looking at future upgrades for my car.
I came across this little gem while comparing a lot of the after market intake systems and this one seemed to be nice to me. I was unable to find anyone who has this entire system installed, most people seem to go with Batinc's, SHOShop, or KKM.
Found at:
K&N Websight Info
It was made for the V6 Cougar and seems to be compatible with non-SVT V6 Contiques. I guess it's due to the IAT placement or the extra hose or whatever.
I realize that with the heatshield could be less than ideal if hot air can still get around it. But generally I think it would look pretty nice as it's an entire assembly that can be dropped in (gotta use the stock MAF though).
Anyways just something I found and something I never saw mentioned here so just thought I'd bring it up.
Comments?
Former owner of a 1995 Contour 2.5L V6 ATX
#1025361 08/11/04 04:44 PM
It's very expensive for what you're getting: A hot-air ingestion device. You can duplicate the performance gain (loss?) for far less by glomming together your own parts. It's not hard.
This has come up before, and that seemed to be the general consensus.
Function before fashion. '96 Contour SE "Toss the Contour into a corner, and it's as easy to catch as a softball thrown by a preschooler." -Edmunds, 1998
#1025362 08/11/04 05:35 PM
You can easily put an intake together using parts that are available on the net. To make sure you're netting real improvements in air flow, keep the MAF adapter and filter neck to at least 3" ID. Your duratec can use the air if you can make it available, especially in the upper RPMs. Some of the cheaper 'universal' parts out there are 3" OD.
#1025363 08/11/04 07:13 PM
K&N ru-3530
Big MAF adapter
Homade heatshield
Same, if not better performance gains than the extremely overpriced K&N unit for under $60.
"...first he's gonna s*!t, then he's gonna kill us." 1999 Contour SVT Retrojunk.com
#1025364 08/13/04 01:33 AM
Hey Jason, so how much power do you think you made from that set-up you have over the stock one? Im thinking of doing exactly what you did.
#1025365 08/13/04 02:35 PM
The nice thing with that kit (at least for us Californians) is that it's CARB legal. I would never have to remove it for a smog check (if I had a Cougar).
dion 98 SVT, 200 whp/190 lb. ft tq (tuned by ADC), 3.0, P&P heads w/2.5L valves, optimized TB, MSDS, SCA 2.5" catback, SHOshop UIM/LIM, underdrive pulley set, TD's, Koni/H&R, BAER/TCE, Progress, CF1 products
#1025366 08/13/04 07:07 PM
Probably not a significant difference being that you don't gain a whole lot from just an intake to begin with.
