Posts: 26 |
What is the compession of the engine? When dealing with an engine of unknown history you should start with some sort of baseline, and this seems to have been overlooked. I would also connect a vaccum gauge to the intake manifold and check reading at idle, take notice of needle fluctuations.
Posts: 1,788 |
My bet is wrong plug wire order. Only thing that explains backfiring.
BTDT.
Steve
89 Taurus SHO - 246K miles
94 SHO ATX - 190K
Posts: 14 |
I so much wish you were right projectSHO89 but i double checked with the donor car and the firing order is the same. and my back just went out so i will not be able to get on your suggestions guys right away but i will appreciate if you keep on throwing me ideas in order to solve this mystery
Posts: 2,017 |
I had a no start, misfiring, rough idle, power loss issue and it turned out to be the fuel pump.
With a fuel pressure gauge installed, turn the key to on, but don't start the engine. Check the priming of the fuel pump. Mine was priming at 5psi on a warm enigine, it should be at 25 psi (I believe) on the 1st prime.
1996 2.5LT V6 Contour ATX My Tour+help/info pics
E0 rims, Gutted Pre-Cats,CTA Custom Exhaust & Intake, Diablo Chip.
