#1023358 08/08/04 11:42 PM
ok thought i would be a smarty and buy and install my own fuel filter due to the fact ford charged my gf 60 bucks for hers i went to napa and bought one installed it and now it seems like when i give it gas to go it wants to choke and act up?? like somethings clogged but only when i try and give it acceleration? any help should i buy a ford fuel filter?
2000 silver frost midnite blue csvt
#1023359 08/08/04 11:52 PM
Did you buy the OEM replacment from Napa?
2003 Toyota Matrix 1972 Pontiac Ventura II "Sprint" 1998 SVT !SOLD!
#1023360 08/08/04 11:58 PM
i assume i did told them what type car i have? yr and all?
#1023361 08/09/04 12:02 AM
never go to napa again. i lost a motor due to their and my ignorance. i went and bought some spark plugs. told them i wanted two ranges colder and they gave me copper cores. didnt even relize it. so the plugs melted and dropped into the cylinder. napa would not cover my damages nor would autolite. turns out the plugs were not even for my car. but their book said so. swapped the motor and they hooked me up with a clutch.... seemed a little big. now their computer said it was for the svt contour...... maybe a mustang cobra... the pressure plate was as big as my flywheel. wtf went back with my original pressure plate and the guy said for me to go to a different store other than napa because there was nothing they could do for me. i said a few words and they pushed me out of the store. at least i got my refund back. a holes. bunch of incompetant a holes. thanks napa.
from my dealings with napa either the filter was installed backwards which is easy to do btw or its for a honda civic.
#1023362 08/09/04 12:09 AM
I have been calling around for fuel filters and every place asked me if I wanted the OEM, or the one a few dollars cheaper. Either way, I do not see why you would have problems.
#1023363 08/09/04 12:14 AM
are you sure you put it in right? you have to install it flowing the right way. i put mine in backwards and the car ran like hell. switched it around and it was fine.
#1023364 08/09/04 05:23 AM
You can pick up a Purolator for under $8. Purolator makes the OEM filter.
Replacement time is about 5 minutes.
#1023365 08/10/04 01:38 AM
yes i did put it in right the arrow goes toward the engine? thats wht the book said but ill flip it around again and try it likr that
#1023366 08/10/04 02:54 AM
actually those wont fit they have to be bolted on, and they look way different
the purolator fuel filter you want is the F63169 from Advance auto parts or a Deutsch FF679 from autozone(its behind the counter gotta ask them for it)
98.5 Black SE ATX S&B filter, SVT MAF, optimized SVT TB, mesh grille, removed orange reflectors, painted rear reflector, gutted pre-cats, optimized SVT LIM, 19lb injectors, resonator removed cant afford an svt but lookin for 1 in nc
#1023367 08/10/04 07:52 AM
you probably put it in backways.... the arrow on the side of the filter points to the flow of gas, not the front of the car.. i had to do a double take on it when replacing mine on a 93 taurus... (same setup on the contour)... get back under the car and look at the arrow again and then look at the hose coming from the fuel tank..... and the hose that goes from the filter to the engine(front of the car)..... real easy to put it in backways.....
