Posts: 118 |
After replacing my fuel pump for nothing (lets call it preventive maintenance...), I am now convinced the CPS is the cause of my intermittent no start condition. Basically when the sensor gets hot, the car does not start.
I am wondering if this part can cause driveability problems also. Is it used for ignition timing also, or is it only useful at start-up? My car is a real dog now, it feels like timing is retarded 20 deg... It might also have a vacuum leak at the upper manifold gaskets.
Last question : My search has turned up 2 part numbers, one which is roughly 25$, and supposedly specific to duratec (5L8Z-6C315-AA) and one that only says V6 in the description, and is 11$ us. (1S7Z-6C315-AA). What is the difference? Which one did you use?
TIA
Marco Tatta
98.5 SE MTX, Duratec
EGR block, indiglo gauges, custom shift boot, monsterflow intake,
Quasi dual cardoctor exhaust.
Hacksaw short shift, Momo race s carbon knob, ghetto rear strut bar, 16 inch cougar wheels with 225/50/16 kumho 712s
Posts: 463 |
If the PCM wasnâ??t receiving a signal from the CPS it would store a code. Best thing is to pull the codes. Yes the Crank and cam sensors are use for timing. Crank and cam sensors basically work or they donâ??t. I have seen one or two that were intermittent. Hard starting when hot is usually a mixture problem, check your ECT sensor for correct hot resistance.
jeff
have you fixed your ford lately?
Posts: 322 |
Originally posted by mangler: ....I am now convinced the CPS is the cause of my intermittent no start condition. Basically when the sensor gets hot, the car does not start.
I had a similar problem....and it ended up being the crankshaft sensor as you are suspecting. My car's symptoms would only occur after I had driven the car for a while and the engine had warmed up, then made a brief stop, and then return and try to start the car...at which point it would crank but not start. If I let it sit for an hour, all of a sudden it would then start. This happened over the course of MONTHS before it totally stopped working and allowed the dealer to figure it out.
The part number for the crank sensor on my receipt from Ford is 1S7Z-6C315-AB. Not sure if its different between standard and svt engines, but thats only different by one letter from the one you posted, so maybe it is just a part revision. Also, for what its worth, on my receipt Ford said they 'replaced wiring to crank sensor' in addition to replacing it. HTH
Jesse
98.5 SVT (sold)
2000 Explorer
Posts: 118 |
Jeff, Jesse, Thanks for the posts. I will be investigating the mixture thing. Unfortunately, I do not get codes. The only way I get codes is by lugging the engine in 5th, I then get a flashing cel (random misfire and misfire cylinder 6). I got a cel once, but disappeared before I could scan  I will be replacing the CPS, at 12$, seems to be a no brainer, and might just solve my starting problems. Maybe changing the upper intake gaskets will cure my lack of power and surging idle. It is behaving alot like a vacuum leak. My short term fuel trim on bank 1 also seems weird, at like -8%, while stft2 is normal (around -1%).
Marco Tatta
Posts: 702 |
Your Surging idle may be from your EGR block....Has this problem been happening since you did that mod?? Ive heard more than a few people having problems blocking off the EGR. It does nothing for performance but no one (including me ) wants that nasty exhaust gas recirculating through their system, So i know why you did it. You might try removing the mod temporarily to see if your erratic idle goes away. Maybe and Maybe not....
CSVT E0 3L
14.5 @ 94mph, Stock Intake, Stock Exhaust minus Resonator, CEL, And Broken Pass. Side CV...Untuned.
Posts: 26 |
I had a no start condition on my V6 that turned out to be either a weak crank senor or the sensor wires and could have been both. I had no trouble codes to aid in the diagnosis. I tested the coil pack and detirmined the there was no signal to trigger spark, so I chose to replace the crank sensor and not the ECU and hope this was my problem. While unplugging the sensor I saw that there was also a wiring problem (the famous biodegradeable wire insulation), which I also repaired. When I compared the old sensor and the new one the ohm readings were not the same and the old senor had an oil varnish on the magnet(160,000 mile on the car). I believe this all contributed to a weak signal. Replaced the sensor, repaired the wires, and the problem was solved. Also , on a side note, I would occationally get a blinking CEL for a stuck TCC sol. that hasn't returned since this repair.
Posts: 121 |
Does the CPS only cut spark? Or will it also cut fuel?
Rusty
'00 silverfrost SVT
'99 black SVT
'86 black SVO
'86 red SVO (for sale)
Posts: 118 |
Silverbullet,
My EGR mod has never given me problems, and the hole is big enough not to trip a CEL. I found it did give me better low throttle response, and keps the upper intake MUCH cleaner. Not saying it can't be, but I will be looking at alot of things before this. Will probably be removing the upper intake and changing the gaskets, I guess I can get a look at it then.
Athos, TCC sol. ? Please explain. All I get is misfires
Marco Tatta
Posts: 26 |
That really was just a side note that probably dosn't apply to this situation, but I thought I would throw it out the in case it might help someone. Now, since you asked... Every once in a while, as I drove, the CEL would begin to blink. The trouble code was for a stuck TCC sol (Torque Converter Clutch). I did the reading, did the suggested fixes, and would still get the blinking light with the same trouble code. It hasn't happened since the replcement of the crank sensor, so I can't help but think that the two were related in someway. Possibly the ECU uses the crank sensor when determining torque converter clutch control, I really don't know.
Posts: 118 |
Well, it's been a while, and I still have my hot start problem. Repaced my camshaft position sensor yesterday, and that did not do much. The wiring looked ok, although I did not know what to look for exactly as far as degradation.
I guess I will be replacing the crankshaft position sensor next. My missing and surging problems did go away with an ignition wire and intake gasket replacement though. Hope the cps will do the trick, I do not know what to look for next...
BTW, can there be a stored code, without an engine CEL? My mechanic said he had scanned it and gotten intermittent camshaft position sensor fault. I have an obd2 scanner from Alex Peper, so I will verify this as soon as I am back.
BTW, is the ECT sensor easily accesible and replaceable? What is the norml hot resistance I should get?
TIA
Marco Tatta
