Ok Here is the problem.. I have gutted pre-cats and i have the mil eliminators.. My Air/fuel ratio guage at idle is on the far lean point.. when driving at half throttle wich seems to have the most power also to my butt it stays in the stoich area and when i hit about 5000-5500 rpms still at half throttle the guage flys over to the lean part and then off the scale.. Now at full throttle it obviously goes off the scale right away..
My car has 104000 miles.. new fuel pump.. wires and sparks are about 25000 miles old(all are what everyone suggest to get auto double plat and stock ford wires) I have a trubendz exhaust and a diablo chip tuned for intake and exhaust.. I have not done the UIM cleaning but I have done the way that you use the vacume line with some b12 cleaner and it works pretty well..
What would cause my car to run so lean? I have searched tons and tons last night and found a lot on bad o2 sensors, not enough spark, and fuel pump... what would you guys suggest on my first step... I have not had a diagnostics done jsut yet.. i will try to get it on saturday or sunday.. any ideas or suggestions would be great
Thanks
