#1021986 08/06/04 05:36 PM
W
W
When I took my car in for the 90K service, they told me the Idle Air Control Valve is sticking and it was causing them to have difficulty starting it. I've never had any trouble starting the car...is this something i should worry about? Also, is it possible to clean it rather than replace it and how hard is it to replace?
W
W
oh yeah, I have the V6 by the way
H
H
Check the FAQs, there is a HowTo to clean it. All you need to do before removing it is by the gasket which is about $1.
by cleaning it you will prevent the thing from having a cold start stall, which when stuck open/closed can and most likely will happen.
Cleaning is only a temp fix, I cleaned mine twice in 7 months. For the $39 from www.autozone.com you may just want to swap it out.
2003 Toyota Matrix 1972 Pontiac Ventura II "Sprint" 1998 SVT !SOLD!
W
W
Is it a hard piece to take out and install?
No. Very easy.
99 CSVT Green/Tan # 84 of 2760 Built on Wednesday, September 30, 1998 15.376 @ 92.00 MPH Stock 75,000Km 96 Contour GL 2.5L V6 ATX 170,000Km
W
W
ok cool....so i should be able to do it myself then....where exactly is it located?
2 10mm bolts, its kind of tight back there.
very tight back there....good luck with the bottom bolt. other than that, very easy to do.
AIM...BKapp17 98 T-red SVT Steeda Gutted Pre-cats, no resonator Painted Dash Angel Eye Fogs Painted Chrome ring / headlights Looking for a t-red pre98 trunk lid
Eh, not that bad, just angle the IAC valve top section to the passenger side of the engine bay, leaving more room to get ur 10mm socket on that bottom bolt.
* Marine Officer Candidate * My Cardomain Page 1998 EO Black SVTC #3388
