Posts: 98 |
I have an extra engine, and mine just hit the 150k mile mark and is starting to give me problems, so I figured I would rebuild the extra.
Have any of my fellow CEG'ers undertaken this yet and if so, does anyone have any good advice or links for sites with aftermarket performance goodies to put back into the motor to attain more power?
This is the first time I will be rebuilding a 4 cyl engine, been rebuilding V-8's since I was 15, just having a hard time finding info on this engine as far as performance engine internals.
Any and all help is appreciated.
Thanks.
'97 Contour 2.0 Zetec
Posts: 6,280 |
It should take half the time to rebuild the 4cylinder compared to the v8's you've done.
Posts: 217 |
Yeah seriously, does anyone know where to get some good zetec-compatible racing cams or something? I'm not rebuilding my engine, but I think it would be interesing and I'm sure 'Touring would appreciate it.
Also, I bet it's easier to put these sorts of mods in WHILE you're rebuilding the engine, not afterwards, right?
Posts: 6,280 |
Look up Burton Power or Dunnel Racing. Both are in England, but they do/did a lot of Zetec tuning stuff. Also Esslinger here in the states.
Posts: 98 |
Thanks for the replies.
Yes Savior, it is always easier to put internals in an engine while its already apart and being worked on.
ChatavegasSE, thanks, I will check them out. The first thing getting done is the Head and Block are gonna take a nice hot bath, then have some port and polishing done.
Thanks again.
Posts: 367 |
Would you do us a favor and keep us updated. My 98 has about 170,000 on it. I am thinking of purchasing a used engine and rebuilding it as well. My intention is a mildly modified engine that will last another 50 or 60k. I am not looking for boost or even a racer but an extremely effecient engine.
Posts: 21,653 |
Just search for focus stuff on yahoo. Plenty of sites will come up. seanhylandmotorsports, zxtuner, and ford racing are all companies with zetec stuff off the top of my head. There are plenty of cam manufacturers, as well as a few piston choices,etc.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 1,224 |
My pile of info.
Some links...
NewEdge Performance - FRPP Head, ARP Head Studs, ARP Main Studs, Crower Camshafts, Eagle Con Rods, Focus Central Throttle Body, Multiple Cam Gears, Under Drive Pulleys
Steeda Focus Online - FRPP Head, FRPP Intake Manifold, Cams, UDPs, Cam Gears
McNews Automotive - FRPP Cams, Cat Cams, Crower Cams, Comp Cams, FRPP Head, FRPP Intake, pretty much everything at very good prices
CTA Motorsports - Cat Cams, Pulleys, Ignition Coils, FRPP Ignition Wires, Chips
Ford Parts Online - OEM parts at pretty much the best prices
Sig LM aka Bill Jenkins - OEM parts at good prices
BAT - Mostly non-engine related parts
Also, beware that the Contour Zetec uses hydraulic lifters and the Focus Zetec uses solid lifters. You will have to match the type of lifter to the cam.
I've been doing a little research over the past couple of years.
HTH,
Ben
Ben ---'96 Contour GL * Zetec ATX * Tan on Black steelies---
+++JRSC M62 Under Construction+++
My big-a$$ mod list.
Posts: 495 |
www.focus-power.com Turbo Tom's site. He does mainly Focus's but he can do our engines as well. His built blocks have done 400+whp FI and 200whp NA in full race trim. Only problem is you get what you pay for and he has a 3 month backlog. If I had the cash I'd get one of his built short blocks. He's the only Zetec builder in the U.S. I'd trust to work on these engines.
2000 Rio Red I4 Cougar
200whp & 210wtq at 9psi
254whp & 276wtq with NX 35shot
WRX TD04 Turbo, Cut Short Shifter, Strut Tower Bar, 17" ZN Wheels, Roush Springs, Starion Intercooler, NX 35 shot, HKS SS BOV, Full 3" exhaust,StreetFlight Chip
Posts: 862 |
I have 147k on my 96. It was driven by a woman before me from 80k till 146k. It runs fines minus some minor lifter noise. Oil is perfectly clean, no knocks, no smoke, good power, sounds awesome, also engine is really clean. It runs great and I know it is a 96 block so that does reduce the possibility of it already being swapped out. I do know that the head has been off before. It also appears possible that the engine may have been removed and put back in, due to marks on certain bolts. Plus the cams are perfectly clean and so is the valve cover on the inside aka no build up. So what do you think? Has it been well taken care of or partial rebuild, or replacement?
ATX MTX swap, rear drum disc swap, drilled rotors, ported intake, optim throttle body, CAI, 7.5L MAF, adj. fuel regulator, longtube headers, underdrive pulley, no EGR, low inpedence bigger injectors, 2002 Focus Swap
